Pihole updates?
uross
Re: Pihole updates?
Post by uross »
strange enough, without further tinkering, the message is gone. some self-healing going on here? will check again next time after a fresh reboot.
mindtrap
Re: Pihole updates?
Post by mindtrap »
I updated tonight from v128 and now notice that I don't see the Pi-Hole logo at the Status screen. It just says "Status". Also, it doesn't show "Active" or "Temp". Further searching on my end seems to show I only have this issue with Firefox.
Pi-hole -- Firefox
Pi-hole -- Firefox
Pi-hole -- Firefox.jpg (6.41 KiB) Viewed 3111 times
When I view the screen via Internet Explorer, everything shows fine.
Pi-hole -- IE11
Pi-hole -- IE11
Pi-hole -- IE.jpg (8.29 KiB) Viewed 3111 times
Is this an issue with my install or is there a browser incompatibility somewhere in the Pi-hole scripting? I notice when the logo was changed, some of the coding was as well -- logo went from .img to .svg for example.
Thanks in advance for any assistance.
Steve
k-plan
Re: Pihole updates?
Post by k-plan »
mindtrap wrote:I notice when the logo was changed, some of the coding was as well -- logo went from .img to .svg for example.
Logo format went from .jpg to .svg
Your browser shows a image if you enter:
http://ip-address-of-your-DietPi-device/pihole/img/logo.svg
Which web server stack use your Pi-Hole installation? apache2, ngnix, lighttp?
mindtrap
Re: Pihole updates?
Post by mindtrap »
Yes, it does.
k-plan wrote:Which web server stack use your Pi-Hole installation? apache2, ngnix, lighttp?
lighttp -- initially selected when configuring the DietPi installation; chosen based on reading the options presented. I don't recall being prompted for this once launching the Pi-Hole installation (if that matters).
Steve
k-plan
Re: Pihole updates?
Post by k-plan »
Hi mindtrap,
tested by myself (PiHole 2.9 on DietPi v130 with lighttp)
left - Chrome  /  right - Firefox
It is a bug in pihole:
https://github.com/pi-hole/AdminLTE/issues/140
https://github.com/pi-hole/pi-hole/issues/693
https://pi-hole.net/forums/topic/web-in ... xchromium/
We have to watch for a while, what will happens on the github issue.
