Hi John,johnvick wrote:
So same result by the looks of it?
Thanks for running those tests.
Yep, very strange.
I've not seen a Size mismatch error in apt before. So i'am not sure how to proceed with further debugging.
It must be due to unique combination of additional apt sources, or, some kind of hardware/memory failure that is causing CRC/filesize checks (i'd assume) to fail and provide incorrect results.
Either way, i'am just thinking out aloud. Unfortunately, at the moment I dont have solution or where to look next. Apologies John, looks like the reinstall might be the only solution at the moment.
