Install Odroid C2 DietPi v127 doesnt work
mathk_ing
Re: Install Odroid C2 DietPi v127 doesnt work
Post by mathk_ing »
I have installed the latest version, but it takes no efffect.
Now it is installed the verison 130.
Fourdee
Post by Fourdee »
mathk_ing wrote:Hi,
Thanks for the report Mathk. Very strange, not unless the locale is causing this. Have you tried running the reboot command before changing the locale to de_DE.UTF-8?
K-Plan, do you use this locale also?
Mathk, whats the revision code on the back of the C2. eg: v0.1 date?
mathk_ing
Post by mathk_ing »
Fourdee wrote:Have you tried running the reboot command before changing the locale to de_DE.UTF-8?
No, sorry.
Now I have deinstall de_DE.UTF-8 an select en_GB-UTF-8. The reboot works. But when I twice reboot, it doesnt start.
What ist K-Plan?
Fourdee wrote:Mathk, whats the revision code on the back of the C2. eg: v0.1 date?
https://picload.org/image/rdrrrcdi/20160918_142234.jpg
k-plan
Post by k-plan »
mathk_ing wrote:What ist K-Plan?
Me ! :D
Fourdee wrote:K-Plan, do you use this locale also?
Yes, but my C2 is running v122 with "old" PiHole version in productive operation. Never touch a good running system! ;)
So it is difficult to test with it. But I will have a look and do my best.
Any wishes? On SD card or on eMMC ? Automated or manually install? With special software to install?
k-plan
Post by k-plan »
mathk_ing wrote:My revision ist 0.2 20160226
Tested:
Odroid C2 PCB Revision: rev0.2 20151218
image:
installed on eMMC: full automated, DHCP Ethernet, AUTO_Locale=de_DE
root@Odroid-C2-TEST:~# cat /var/log/boottime
14.56 Seconds
root@Odroid-C2-TEST:~# uname -a
Linux Odroid-C2-TEST 3.14.78+ #1 SMP PREEMPT Sun Sep 11 13:16:51 CEST 2016 aarch64 GNU/Linux
work , auto-reboot after initial installation without problems
Have as well tried several times :
root@Odroid-C2-TEST:~# reboot     ## reboot
root@Odroid-C2-TEST:~# shutdown -r 0      ## reboot
root@Odroid-C2-TEST:~# poweroff       ### shutdown/poweroff/halt
dietpi-software => installed some software => auto-reboot (without a problem)
dietpi-config => change device name => auto-reboot (without a problem)
mathk_ing wrote:it is the same
root@c2:/home/user# shutdown -r 0
Shutdown scheduled for Mon 2016-09-12 22:00:45 CEST, use 'shutdown -c' to cancel.
root@c2:/home/user#
hmm, why
/home/user
Have you add a user? Change something in user management or passwords? Done modding in .bashrc or startup scripts?
Can you please try:
root@Odroid-C2-TEST:~# sudo reboot
or
root@Odroid-C2-TEST:~# sudo su
                                :~# reboot
