Nextcloud Apache virtualhost and ocm-provider/ocs-provider redirect
Re: Nextcloud Apache virtualhost and ocm-provider/ocs-provider redirect
ncc maintenance:update:htaccess should have been it, there was a typo, sorry.
But that error is on a different level, probably related to the wrong rewrites?
Let's apply the change manually. Can you please paste:
cat /var/www/nextcloud/.htaccess
bbkhdt
Post by bbkhdt »
Here is the output of cat /var/www/nextcloud/.htaccess
<IfModule mod_headers.c>
  <IfModule mod_setenvif.c>
    <IfModule mod_fcgid.c>
       SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
       RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
    </IfModule>
    <IfModule mod_proxy_fcgi.c>
       SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
    </IfModule>
  </IfModule>
  <IfModule mod_env.c>
    # Add security and privacy related headers
    # Avoid doubled headers by unsetting headers in "onsuccess" table,
    # then add headers to "always" table: https://github.com/nextcloud/server/pull/19002
    Header onsuccess unset Referrer-Policy
    Header always set Referrer-Policy "no-referrer"
    Header onsuccess unset X-Content-Type-Options
    Header always set X-Content-Type-Options "nosniff"
    Header onsuccess unset X-Download-Options
    Header always set X-Download-Options "noopen"
    Header onsuccess unset X-Frame-Options
    Header always set X-Frame-Options "SAMEORIGIN"
    Header onsuccess unset X-Permitted-Cross-Domain-Policies
    Header always set X-Permitted-Cross-Domain-Policies "none"
    Header onsuccess unset X-Robots-Tag
    Header always set X-Robots-Tag "none"
    Header onsuccess unset X-XSS-Protection
    Header always set X-XSS-Protection "1; mode=block"
    SetEnv modHeadersAvailable true
  </IfModule>
  # Add cache control for static resources
  <FilesMatch "\.(css|js|svg|gif)$">
    Header set Cache-Control "max-age=15778463"
  </FilesMatch>
  # Let browsers cache WOFF files for a week
  <FilesMatch "\.woff2?$">
    Header set Cache-Control "max-age=604800"
  </FilesMatch>
</IfModule>
<IfModule mod_php7.c>
  php_value mbstring.func_overload 0
  php_value default_charset 'UTF-8'
  php_value output_buffering 0
    SetEnv htaccessWorking true
  </IfModule>
</IfModule>
<IfModule mod_rewrite.c>
  RewriteEngine on
  RewriteCond %{HTTP_USER_AGENT} DavClnt
  RewriteRule ^$ /remote.php/webdav/ [L,R=302]
  RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
  RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L]
  RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L]
  RewriteRule ^remote/(.*) remote.php [QSA,L]
  RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
  RewriteRule ^\.well-known/(?!acme-challenge|pki-validation) /index.php [QSA,L]
  RewriteRule ^(?:\.(?!well-known)|autotest|occ|issue|indie|db_|console).* - [R=404,L]
</IfModule>
<IfModule mod_mime.c>
  AddType image/svg+xml svg svgz
  AddEncoding gzip svgz
</IfModule>
<IfModule mod_dir.c>
  DirectoryIndex index.php index.html
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
<IfModule pagespeed_module>
  ModPagespeed Off
</IfModule>
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 /nextcloud/
ErrorDocument 404 /nextcloud/
  Options -MultiViews
  RewriteRule ^core/js/oc.js$ index.php [PT,E=PATH_INFO:$1]
  RewriteRule ^core/preview.png$ index.php [PT,E=PATH_INFO:$1]
  RewriteCond %{REQUEST_FILENAME} !\.(css|js|svg|gif|png|html|ttf|woff2?|ico|jpg|jpeg|map|webm|mp4|mp3|ogg|wav)$
  RewriteCond %{REQUEST_FILENAME} !core/img/favicon.ico$
  RewriteCond %{REQUEST_FILENAME} !core/img/manifest.json$
  RewriteCond %{REQUEST_FILENAME} !/remote.php
  RewriteCond %{REQUEST_FILENAME} !/public.php
  RewriteCond %{REQUEST_FILENAME} !/cron.php
  RewriteCond %{REQUEST_FILENAME} !/core/ajax/update.php
  RewriteCond %{REQUEST_FILENAME} !/status.php
  RewriteCond %{REQUEST_FILENAME} !/ocs/v1.php
  RewriteCond %{REQUEST_FILENAME} !/ocs/v2.php
  RewriteCond %{REQUEST_FILENAME} !/robots.txt
  RewriteCond %{REQUEST_FILENAME} !/updater/
  RewriteCond %{REQUEST_FILENAME} !/ocs-provider/
  RewriteCond %{REQUEST_FILENAME} !/ocm-provider/
  RewriteCond %{REQUEST_URI} !^/\.well-known/(acme-challenge|pki-validation)/.*
  RewriteCond %{REQUEST_FILENAME} !/richdocumentscode(_arm64)?/proxy.php$
  RewriteRule . index.php [PT,E=PATH_INFO:$1]
  RewriteBase /nextcloud
    SetEnv front_controller_active true
      DirectorySlash off
    </IfModule>
  </IfModule>
</IfModule>
For some weird reason my console doesn't know the commands ncc and occ.
did you install NextCloud via dietpi-software? because DietPi has added shortcut ncc to simplify configuration. Otherwise it is needed to use full command sudo -u www-data php /var/www/nextcloud/occ
bbkhdt
Post by bbkhdt »
Yes, I did, it's really weird.
Could it have to do with me moving the userdata directory to the harddrive?
Here's the output of cat /var/www/nextcloud/.htaccess after applying sudo -u www-data php /var/www/nextcloud/occ maintenance:update:htaccess (sucessfully :P).
    </IfModule>
    </IfModule>
  </IfModule>
  </IfModule>
  </FilesMatch>
  </FilesMatch>
</IfModule>
  </IfModule>
</IfModule>
  RewriteEngine on
</IfModule>
</IfModule>
</IfModule>
Options -Indexes
  ModPagespeed Off
</IfModule>
ErrorDocument 403 /
ErrorDocument 404 /
  Options -MultiViews
      DirectorySlash off
    </IfModule>
  </IfModule>
</IfModule>
That one is still wrong, somehow. Change it to RewriteBase /.
bbkhdt
Post by bbkhdt »
In the meantime, thanks to your help, I managed to get the thing running as intended. I'll post a short documentation of what I did here shortly.
Thanks a million @MichaIng and @Joulinar! :D
Is there some way I could support the dietpi effort?
You could follow this link if you like to support the project https://dietpi.com/contribute.html
bbkhdt
Post by bbkhdt »
Sorry, I've got another question:
In the Nextcloud settings I now get a notification, that the server cannot handle
  • "/.well-known/caldav"
  • "/.well-known/carddav"
  • "/.well-known/webfinger"
  • "/.well-known/nodeinfo"
  RewriteEngine on
  RewriteRule ^\.well-known/carddav /nextcloud/remote.php/dav [R=301,L]
  RewriteRule ^\.well-known/caldav /nextcloud/remote.php/dav [R=301,L]
</IfModule>
In the Nexcloud-Doc it says that the rules given above need to be set somewhere in the .htaccess file of the DocumentRoot. However I'm not sure whether which .htaccess file is the right one. If it's supposed to go into var/etc/nextcloud where exactly are they supposed to go?
    </IfModule>
    </IfModule>
  </IfModule>
  </IfModule>
  </FilesMatch>
  </FilesMatch>
</IfModule>
  </IfModule>
</IfModule>
  RewriteEngine on
</IfModule>
</IfModule>
</IfModule>
Options -Indexes
  ModPagespeed Off
</IfModule>
ErrorDocument 403 /
ErrorDocument 404 /
  Options -MultiViews
  RewriteBase /
      DirectorySlash off
    </IfModule>
  </IfModule>
</IfModule>
Here is my virtual host config file.
<VirtualHost *:80>
	ServerName test.***.de
	DocumentRoot /var/www/nextcloud
#	Redirect permanent /.well-known/webfinger /nextcloud/index.php/.well-known/webfinger
#	Redirect permanent /.well-known/nodeinfo /nextcloud/index.php/.well-known/nodeinfo
	<Directory /var/www/nextcloud>
	Require all granted
	AllowOverride All
	Options FollowSymLinks
	<IfModule mod_dav.c>
		Dav off
	</IfModule>
	# https://github.com/MichaIng/DietPi/issues/3694
	Header unset Content-Security-Policy
	Header always unset Content-Security-Policy
	</Directory>
	ErrorLog ${APACHE_LOG_DIR}/cloud-error.log
	#CustomLog ${APACHE_LOG_DIR}/access.log combined
RewriteEngine on
RewriteCond %{SERVER_NAME} =test.***.de
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
For all rewrite rules, the leading /nextcloud needs to be removed, as your document root is inside this directory already. And the rules for CalDAV + CardDAV (both not required but allow calendar sync clients to find Nextcloud calendars by using the raw domain only) are inside your .htaccess already. But we add them on install for the case that webroot is /var/www, which would conflict, so disable those:
a2disconf dietpi-dav
I that name is wrong, please check the right one in /etc/apache2/conf-enabled/.
