Stretch to Buster Upgrade
ilgrank2
Re: Stretch to Buster Upgrade
Post by ilgrank2 »
just out of curiosity..
...has this possibility happened? :)
yes Stretch is still supported with DietPi scripts. However it could happen that Debian software packages will not be updated anymore. But this is out of DietPi control as DietPi is taking care on their own scripts only.
zaurux
Post by zaurux »
But when DietPi builds on Stretch switches to Buster and its upgraded programs (ex: NAA 3.60 on Strech and 4.1.1 on Buster) ? ;)
well that's a pure functionality of Debian. Changing the source list to Buster will lead to update all available packages the the buster version as well.
zaurux
Post by zaurux »
No DietPi script.. I change source via apt ?? a howto ? has the subject already been discussed on the forum ?
or just an edit of /etc/apt/sources.list
deb http://deb.debian.org/debian/ buster main
well it's linked on first page already. If you like to take the risk of upgrading from Stretch to Buster, you may have a look into the following post
viewtopic.php?p=18988#p18988
roundcubeseven
Post by roundcubeseven »
The rule of thumb is, the less software installed on your system, the higher chance for a successful upgrade. The chances for a successful and fully functional upgrade are decreased by a number of 3rd-party packages installed on your current system. From this reason, remove any obsolete standard repository and 3rd-party software before you attempt the upgrade. The aptitude command might help you to find any 3rd party software package currently installed on your Debian system.
