SSH Stop working : Network error connection refused
trendy
Re: SSH Stop working : Network error connection refused
Post by trendy »
I am not able to reproduce this problem.
I remember in the past I changed the CPU Affinitiy, Sch. Policy, etc for processes, including dropbear and it never hanged.
I just tried it now and it still is responsive after restarting the dropbear service.
dietpi@odroid:[~]$ cat /etc/systemd/system/dropbear.service.d/dietpi-process_tool.conf
# WARNING: Do not manually edit this file, use "dietpi-services" to adjust values!
[Service]
CPUAffinity=0,1
CPUSchedulingPolicy=rr
CPUSchedulingPriority=64
IOSchedulingClass=realtime
bricolodu13
Post by bricolodu13 »
Thank you for trying.
Each of my setups, even bare minimal experience the same since long time ago...
I'm the expert in having strange bugs not only software ones...
r33s
Post by r33s »
Same problem for me happened 2 times.
Can't access from ssh, and other services (http, samba..).
Connecting monitor to hdmi : no signal.
But pings replied...
I am on RPi 3 Model B (armv7l) - DietPi v6.30.0 , issue happened at same time when very huge nzb downloaded from sabnzb.
I think it's cpu or ram issue, when sabnzb calculate all file before doing extract.
After 4 hours I decided to power off/on rpi, at now par2 it taking a lot of cpu and memory usage
I sent a bug report if it has any information, reference code: 1b578e79-c7bf-44af-9d97-4ca47016f2e0
possibly that you are running out of CPU/Memory. As well I/O could be an issue. Are you going to download to an external device/HDD? If yes, which file system format did it use?
r33s
Post by r33s »
Thanks for replying very fast :)
Yes, I have set Dietpi userdata to external usb drive, it's a RAID 5 formated in ext4.
ok for testing purposes could you attach some USB stick and format it using ntfs and us it as target directory?
r33s
Post by r33s »
For now I have other huge item into sabznb queue. I think I have an external USB drive formated in ntsf.
I can test it, but this will take days.
Why ext4 formated drive should be a problem ?
it's just an idea based on this GitHub post https://github.com/MichaIng/DietPi/issues/3330
Not sure if it will help but something we can try out
r33s
Post by r33s »
I read all issue messages, yes it very interesting and similar.
But it happened 2 times, I downloaded lot of other very huge (and similar files like today) with sabnzb without errors. :/
Did you think I can install netdata to monitor and keep history for log etc. ?
I was never using netdata. So not sure what type of history it will keep.
