The new Raspberry Pi 4 Topic is solved
Re: The new Raspberry Pi 4
@lpw
I just created a PR to allow ownCloud install with PHP7.3 due to recent release: https://github.com/MichaIng/DietPi/pull/3169
After updating to DietPi v6.26, please try:
wget https://raw.githubusercontent.com/MichaIng/DietPi/owncloud/dietpi/dietpi-software -O /DietPi/dietpi/dietpi-software
This should allow you to install ownCloud on RPi1/Zero and Buster-based systems via dietpi-software.
I will keep this branch active until v6.27 release, since it does not contain any other changes yet, hence is safe to use on v6.26.
pakikje
Post by pakikje »
@MichaIng,
I did a clean install ( official dietpi ) and transfered the Userdate to SSD. I got lots of errors at reboot (see attachements) It seems that the Pi4 now boots into save mode.
Photos.zip
(4.53 MiB) Downloaded 85 times
ThAnEb
Post by ThAnEb »
pakikje wrote: Fri Oct 18, 2019 10:25 pm @MichaIng,
I did a clean install and transfered the rootFS to SSD. I got lots of errors at reboot (see attachements) It seems that the Pi4 now boots into save mode.
you went with the official dietpi img or my experimental (debian) one ?
I putted a first commented version of the script I made to largely automate creation of a debian arm64 for rpi on a external drive (for now it's targeting sda2, so be sure to have only one external drive connected), if you want to use it, it's a simple copy paste into a terminal, few "enter" hits, one password to choose and one " ./buildcontinue.sh " to enter
https://github.com/thaneb/Debian-System ... tobuild.sh
after the reboot, you can install DietPi with the
bash -c "$(curl -sSL https://raw.githubusercontent.com/MichaIng/DietPi/master/PREP_SYSTEM_FOR_DIETPI.sh)"
I wanted to improve the script with arguments and drives/partitions detection and choices options, but my family doesn't help me to have enough free time to improve my bash knowledge to go as fast as I would like ^^
pakikje
Post by pakikje »
@ ThAnEb, I will have to redownload the experimental dietpi-img but it's hard! (link/site doesn't work always, even if i allow flash/ads/cookies/everything)
ps: downloaded with edge this time. Don't know why i have to use a different browser every time (?)
ps2: Moving userdata to ssd worked (reboot went fine) using dietpi-menu.
ps3: i am installing smb/nfs/syncthing and homeassistant now..
ThAnEb
Post by ThAnEb »
pakikje wrote: Sun Oct 20, 2019 3:31 pm @ ThAnEb, I will have to redownload the experimental dietpi-img but it's hard! (link/site doesn't work always, even if i allow flash/ads/cookies/everything)
Sorry for the issue you encountering with 1fichier, i never had any issue with them for dl (from France, Switzerland or Thailand), but i will look for an alternative file holster tomorrow for make it more smooth. A good alternative (that can be also a good way to learn more about debian distrib) , may be to look the script i putted on github and other maybe adapt it for specific needs or installation, at the end you dl almost the same amount of data, but you start to know how to make your own debian kitchen ^^
EDIT : I just change the usb adapter used for my "rootfs" ssd, and it was not booting... thanks to its led activity status, I saw that it was late to switch on, so I moved the drive to a self powered usb 3.0 hub, and of course, it boots without any issue.
So, have to know that depending on the usb adapter used, a self powered hub may be required to allow the boot.
Hey guys, just a suggestion:
Probably is is beneficial to discuss the RPi x64 topic in a separate thread here or GitHub issue? I really like to collect experiences, especially since an x64 kernel is now officially integrated into the new RPi Buster firmware packages. Any testing and error collection should be helpful to report back to RPi developers, and by this help to have a soon Raspbian x64 release with stabilised firmware.
In this thread, where it was about RPi4 support with regular x32 Raspbian, it is probably confusing for others, reading it?
ThAnEb
Post by ThAnEb »
MichaIng wrote: Wed Oct 23, 2019 2:34 pm Hey guys, just a suggestion:
Ok, I got the point, sorry, i will look where it would be the most relevant to speak about that, sorry for the mess here :/
pakikje
Post by pakikje »
Sorry MichaIng.
Will stick with pure DietPi for now...
As said, I don't want to break any testing with this, as IMO x64 should become default for SBCs quickly as well, and its somehow a mess that already RPi2 PBC 1.2 actually has an ARMv8 (x64) capable CPU but Raspbian is compiled for ARMv6 (armv6hf).
So playing with the new x64 kernel totally makes sense, but a separate thread allows better tracking, not disturbed by other posts that are related to RPi4 in general (as of topic).
pakikje
Post by pakikje »
Just to mention:
On DietPi v6.26.3, booting from ssd (rootfs) works if the ssd (on a usb to sata cable) is on a powered-usb-hub.
Syncthing can be installed but no lamp-stack is installed automatic.
