The new Raspberry Pi 4 Topic is solved
pakikje
Re: The new Raspberry Pi 4
Post by pakikje »
@ThAnEb,
Sounds great!!
thnx!
pakikje
Post by pakikje »
Hey melaniestaines,
Linux isn't quiet ready for the pi4 as i understand it. It's a waiting / testing -game right now.
ThAnEb
Post by ThAnEb »
melaniestaines wrote: Wed Oct 09, 2019 8:52 am Hey all. Got my Pi4, 4gb memory, 256gb SanDisk Ultra A1 micro SD, I have gigabit internet, all cat6A ethernet in my home. PC, Synology get full gig speeds. But the Pi is only giving me 15mbps download? What gives? Just installed fresh Raspberian Buster. Any help is appreciated.
Hum, how to say that.. maybe i’m wrong, but .. from my point of view it’s not a big surprise.. if you install dietpi (by using the dietpi PREP script available on github for exemple) you will have at first setup (and later with the dietpi-config or dietpi-drive_manager ) an advanced option to bench drive (your sd card).. you should test it for have a better idea.. i bet 80 boursouf that’s what limiting you..
https://www.tomshardware.com/news/raspb ... 39811.html
@pakikje
I tried the install of home assistant with the DietpiOnKali.. unfortunately, there’s one dependency that cannot be satisfied, it seems it's a library to be replaced soon by another one, i don’t have too much free time these days for start to dig in the home assistant project and look for a manual install, but i think it could be possible.. however, i was thinking about the img i posted , in few weeks, there’s some reasonable chances that all the packages may get an update in stable debian branch, that means, when it will happens, this image will be a 100% arm64 debian with a tuned kernel.. (and all the dietpi debian function will of course work normally). By the way, if use it now and switch repo to debian unstable, everything should be installable, but considered as unstable by debian ^^
ThAnEb
Post by ThAnEb »
pakikje wrote: Sat Oct 05, 2019 3:01 pm @ThAnEb,
Sounds great!!
thnx!
Good news for you :-)
I just bought a new sdcard, installed my kali2debian dietpi img, and then change the apt source from buster to bullseye (which seems to be the testing branch, the one between the stable (buster) and the unstable, and guess what ? :-D :-D
there's no apt's dependency issue anymore when asking dietpi-software to install home assistant !! that doesn't means it will work 100%, but it's already better than nothing !
root@DietPi:~# cat /etc/apt/sources.list
deb https://deb.debian.org/debian/ bullseye main contrib non-free
deb https://deb.debian.org/debian/ bullseye-updates main contrib non-free
deb http://security.debian.org/debian-security bullseye-security/updates main
deb https://deb.debian.org/debian/ bullseye-backports main contrib non-free
Next step is to come back to a debian official kernel, I'm going to dig in that way...
pakikje
Post by pakikje »
thnx for the work man! appreciate it.. 8)
ThAnEb
Post by ThAnEb »
pakikje wrote: Thu Oct 10, 2019 7:39 pm thnx for the work man! appreciate it.. 8)
you're welcome, I'm also doing it for me ;-)
Now that I'm working with a full arm64 debian bullseye on the rpi4 , and as I can see there's still some artifact from the original Kali, I'm giving a try to create a pure debian buster arm64 .img (including the original kernel), I'll keep you updated asap
root@DietPi:/# uname -a
Linux DietPi 4.19.76-v8+ #1272 SMP PREEMPT Fri Oct 4 15:11:39 BST 2019 aarch64 GNU/Linux
EDIT: So I got a pure debian arm64 buster running the dietpi script installed confirms the good ram access found earlier with the kali kernel. After one week to searching around, I'm clearly a big noob as I didn't copy the /lib/modules while deploying the kernel, that leads to many issues :lol: , but it's fix now, only issue i still need to fix is the "freeze state" for usb input devices when deploying a desktop environment, the buster dietpi-debian-arm64.img should be ready very soon here (for raspberry pi 4 only) !
ThAnEb
Post by ThAnEb »
* here's the pure debian arm64 buster (user/pass debian/debian) for Raspberry Pi 4 only (dropbear included) :
https://1fichier.com/?1eeyir2gpdw3eho7fhes
* here's the dietpi img made from the pure debian above (dietpi/root dietpi) for Raspberry Pi 4 only :
removed due to issue (original sd card (deb+diet PREP) was ok, but seems an issue happened when i made an img from it)
use the debian img and apply the PREP script...
bash -c "$(curl -sSL https://raw.githubusercontent.com/MichaIng/DietPi/master/PREP_SYSTEM_FOR_DIETPI.sh)"
WiFi ok, Ethernet ok, Bluetooth ok.. I'm still testing how the dietpi set is working on it :-)
Linux debian 4.19.76-v8+ #1272 SMP PREEMPT Fri Oct 4 15:11:39 BST 2019 aarch64 GNU/Linux
pakikje
Post by pakikje »
TNNX! will be testing too!
rosswesleyporter
Post by rosswesleyporter »
Do I correctly understand that I can simply install DietPi the normal way on my Pi4? Based on MichaelIng in this thread, "...just made the experimental image the new default download." I don't need Pi4 specific features to work e.g. I don't need dual HDMI (or any HDMI actually). But I do want to install some basic audio apps, create an image of the SD card, and have that image also work on a PiZero and a Pi3B+. Thanks for any info.
lpw
Post by lpw »
I'm trying to install ownCloud on an Raspberry Pi 4 using DietPi but don't have the option, it just shows other cloud-solutions like NextCloud.
Am I missing something? Is this worked on or has DietPi transitioned away from ownCloud?
It is still on the software-list and I can't find anything about which platforms should support which software.
