dtoverlay=gpio-shutdown,gpio_pin=3,active_low=1,gpio_pull=up
Re: dtoverlay=gpio-shutdown,gpio_pin=3,active_low=1,gpio_pull=up
systemd-logind is masked by default on DietPi and can be unmask on first initial boot if needed
# Unmask (enable) systemd-logind service (including dbus), which is masked by default on DietPi
AUTO_UNMASK_LOGIND=0
Yes indeed we have it masked by default since it cannot be "disabled" only. Can be toggled via dietpi.txt AUTO_UNMASK_LOGIND=1 setting before first boot or any dietpi-software install to have it unmasked, and it will be unmasked automatically if dietpi-software finds libpam-systemd installed.
But outstanding indeed is to have this well prominent documented, including a list of things which require it.
