dtoverlay=gpio-shutdown,gpio_pin=3,active_low=1,gpio_pull=up
Deleted User 5820
Re: dtoverlay=gpio-shutdown,gpio_pin=3,active_low=1,gpio_pull=up
Post by Deleted User 5820 »
@MichaIng
Also if I run dtoverlay -l I get No overlays loaded
@johncolman
lsmod is the command you should use and the output should contain gpio_keys.
dtoverlay -l only shows the overlays loaded at runtime, thus not the ones added to config.txt.
Note as mentioned above that the syntax for loading overlays at runtime is slightly different, e.g.:
dtoverlay gpio-shutdown gpio_pin=3 active_low=1 gpio_pull=up
Not sure currently if this fails, when loaded via config.txt already, but AFAIK it works. Then you can check via dtoverlay -l if it has been successfully loaded, respectively otherwise the first will throw an error message already.
If overlay and module is loaded and systemd-logind running (systemctl status systemd-logind) and the shutdown button does still not work, then we have to check if the pins are responding as expected. I don't have the commands here, but it is possible to send input to the keys from command lines as well, as well as checking the current state of the physical pins.
Deleted User 5820
Ok typed the wrong thing for lsmod, this is the reply from lsmod
gpio_keys 9575 0
When I run the overlay from the command line with spaces I get
* Failed to apply overlay '0_gpio-shutdown' (kernel)
This is what I get when I run systemctl
root@DietPi:~# systemctl unmask systemd-logind
root@DietPi:~# systemctl status systemd-logind
● systemd-logind.service - Login Service
Loaded: loaded (/lib/systemd/system/systemd-logind.service; static; vendor preset: enabled)
Active: inactive (dead)
Condition: start condition failed at Sat 2019-08-17 22:06:53 BST; 1 day 19h ago
Docs: man:systemd-logind.service(8)
man:logind.conf(5)
http://www.freedesktop.org/wiki/Software/systemd/logind
http://www.freedesktop.org/wiki/Softwar ... /multiseat
@johncolman
Ah that's it, dbus is missing, didn't think about that:
G_AGI dbus
systemctl restart systemd-logind
Actually libpam-systemd might be required as well: G_AGI libpam-systemd
Deleted User 5820
Bingo
It shuts down and a second click of the button it restarts. Tried it a few times and works ok. I will try adding the super capacitor UPS on pin 18 next.
Thanks very much.
@johncolman
Great, probably some info we should add somewhere, at least to dietpi.txt where you can set systemd-logind to be enabled prior to first boot.
Was dbus sufficient or libpam-systemd required as well?
Deleted User 5820
Sorry I ran both first time before trying.
Okay, could be tested, but actually the docs state that libpam-systemd is required for logind functionality in general: https://packages.debian.org/stretch/libpam-systemd
The only other thing that systemd-logind does, AFAIK, is automatically spawning gettys on demand, but not tracking/handling any session tasks.
Deleted User 5820
I just done another install and I didn't need to run G_AGI libpam-systemd for it to work.
AnBad
Post by AnBad »
For what ever reason I had to unmask the systemd-logind.
Install:
G_AGI dbus
sudo systemctl unmask systemd-logind
Bootconfig change:
sudo nano /boot/config.txt
reboot
I am looking for a way to change the power up from Pin 3 to Pin 21, cause Pin 3 is already in use.
