Jackett not working?
Re: Jackett not working?
@canabino
Ah yeah just had the other topic opened :D.
Okay so all this matches, saying it's indeed ARMv8, of course the ROCK Pi 4 with RK3399 is :lol:!
But the question is now why APT/dpkg wants to install armhf packages. Lets check which other packages from which architecture are installed already:
dpkg -l | grep ':arm64' | wc -l
dpkg -l | grep ':armhf' | wc -l
I will also check the image you mentioned in the other topic.
___________________
Okay as of the other topic, the issue is an armhf image on an ARMv8 chip, which I never faced before.
You could try to hardcode ARMv7 as well into DietPi:
sed -i '/G_HW_ARCH_DESCRIPTION=/c\G_HW_ARCH_DESCRIPTION=armv7l' /DietPi/dietpi/func/dietpi-globals
sed -i '/G_HW_ARCH_DESCRIPTION=/c\G_HW_ARCH_DESCRIPTION=armv7l' /DietPi/dietpi/func/dietpi-obtain_hw_model
. /DietPi/dietpi/func/dietpi-globals
dietpi-software reinstall 147
Ah and while I write you were faster. Can you link the image you finally used? But again, lets switch to GitHub to not further force off-topic here ;): https://github.com/MichaIng/DietPi/issues/2445
