Jackett not working?
Re: Jackett not working?
@canabino
Lets check one-by-one:
cd /tmp
wget https://dietpi.com/downloads/binaries/all/libssl1.0.0_1.0.1t-1+deb8u7_arm64.deb
dpkg -i libssl1.0.0_1.0.1t-1+deb8u7_arm64.deb
Which error message does that show?
canabino
Post by canabino »
Hi @MichaIng Thanks for responding.
It is able to download the package but comes up with errors on dpkg.
Saving to: ‘libssl1.0.0_1.0.1t-1+deb8u7_arm64.deb’
libssl1.0.0_1.0.1t-1+deb8u7_arm64.d 100%[===================================================================>] 844.46K 429KB/s in 2.0s
2019-06-09 07:46:47 (429 KB/s) - ‘libssl1.0.0_1.0.1t-1+deb8u7_arm64.deb’ saved [864732/864732]
root@DietPi:/tmp# dpkg -i libssl1.0.0_1.0.1t-1+deb8u7_arm64.deb
dpkg: error processing archive libssl1.0.0_1.0.1t-1+deb8u7_arm64.deb (--install):
package architecture (arm64) does not match system (armhf)
Errors were encountered while processing:
root@DietPi:/tmp#
hd888
Post by hd888 »
I have uninstalled and installed several times and it will work for a day or two then fail.
This is the error msg I receive. I have uninstalled it for now:
n 08 10:50:52 DietPi systemd[1]: Started Jackett Daemon (DietPi).
Jun 08 10:50:53 DietPi jackett[1529]: 06-08 10:50:53 Info Starting Jackett v0.11.391.0
Jun 08 10:50:53 DietPi jackett[1529]: Unhandled Exception: System.BadImageFormatException: Could not load file or assembly 'Newtonsoft.Json, Version=12.0.0.0, Culture=neutral, P
ublicKeyToken=30ad4fe6b2a6aeed'. The module was expected to contain an assembly manifest.
Jun 08 10:50:53 DietPi jackett[1529]:    at Jackett.Common.Services.ConfigurationService.BuildServerConfig(RuntimeSettings runtimeSettings)
Jun 08 10:50:53 DietPi jackett[1529]:    at Jackett.Server.Program.Main(String[] args) in /home/appveyor/projects/jackett/src/Jackett.Server/Program.cs:line 120
Jun 08 10:50:53 DietPi systemd[1]: jackett.service: Main process exited, code=killed, status=6/ABRT
Jun 08 10:50:53 DietPi systemd[1]: jackett.service: Unit entered failed state.
Jun 08 10:50:53 DietPi systemd[1]: jackett.service: Failed with result 'signal'.
Jun 08 10:50:58 DietPi systemd[1]: jackett.service: Service hold-off time over, scheduling restart.
Jun 08 10:50:58 DietPi systemd[1]: Stopped Jackett Daemon (DietPi).
Jun 08 10:50:58 DietPi systemd[1]: Started Jackett Daemon (DietPi).
Jun 08 10:50:58 DietPi jackett[1541]: 06-08 10:50:58 Info Starting Jackett v0.11.391.0
Jun 08 10:50:58 DietPi jackett[1541]: Unhandled Exception: System.BadImageFormatException: Could not load file or assembly 'Newtonsoft.Json, Version=12.0.0.0, Culture=neutral, P
Jun 08 10:50:58 DietPi jackett[1541]:    at Jackett.Common.Services.ConfigurationService.BuildServerConfig(RuntimeSettings runtimeSettings)
Jun 08 10:50:58 DietPi jackett[1541]:    at Jackett.Server.Program.Main(String[] args) in /home/appveyor/projects/jackett/src/Jackett.Server/Program.cs:line 120
Jun 08 10:50:58 DietPi systemd[1]: jackett.service: Main process exited, code=killed, status=6/ABRT
Jun 08 10:50:58 DietPi systemd[1]: jackett.service: Unit entered failed state.
Jun 08 10:50:58 DietPi systemd[1]: jackett.service: Failed with result 'signal'.
Jun 08 10:51:03 DietPi systemd[1]: jackett.service: Service hold-off time over, scheduling restart.
Jun 08 10:51:03 DietPi systemd[1]: Stopped Jackett Daemon (DietPi).
@hd888
AFAIK there is still an open issue with the auto updater that makes Jackett service fail.
Is it possible to disable the internal auto updater and update checker?
dietpi-software reinstall 147 at least is the slightly shorter method to solve it the hard way.
Check out: https://github.com/MichaIng/DietPi/issues/2593
@canabino
Sorry seams like I missed your answer. I gave you commands for the wrong architecture accidentally, please try instead (if issue still persists):
cd /tmp
wget https://dietpi.com/downloads/binaries/all/libssl1.0.0_1.0.1t-1+deb8u7_armhf.deb
dpkg -i libssl1.0.0_1.0.1t-1+deb8u7_armhf.deb
canabino
Post by canabino »
@MichaIng
I followed your instructions and libssl installed correctly. I then rebooted but Jackett still didn't work.
I then ran
The same errors appeared during install. See pic. And Jackett still won't start.
@canabino
Okay now I am confused. Which SBC device do you use?
DietPi-Software identifies it as ARMv8/arm64 and (attempts to) installs libssl1.0.0 and Jackett accordingly. But when manually attempting this DPKG said: package architecture (arm64) does not match system (armhf)
Please paste:
echo $G_HW_MODEL_DESCRIPTION
uname -a
canabino
Post by canabino »
@MichaIng
I use the ROCK PI 4 from RADXA.
Here is the result for the code
root@DietPi:~# echo $G_HW_MODEL_DESCRIPTION
Generic Device (aarch64)
root@DietPi:~# uname -a
Linux DietPi 4.4.154.c83-00028-gaeed0d91c4a7 #17 SMP Thu Apr 18 14:28:51 CDT 2019 aarch64 GNU/Linux
canabino
Post by canabino »
@MichaIng
Here are the results.
root@DietPi:~# dpkg -l | grep ':arm64' | wc -l
195
root@DietPi:~# dpkg -l | grep ':armhf' | wc -l
0
canabino
Post by canabino »
@MichaIng
I got Jackett working again on RADXA's Armbian image.
I am running on RADXA's ROCK PI 4 from this post
I converted their Debian stretch image to DietPi.
I got this from their forum:
Radxa’s apt repository is a mess, many of their “stretch ARM64” debs were built on Ubuntu, they will break Debian ARM64 if you run “sudo apt upgrade” without any protection.
I installed their Armbian image and converted it to DietPi and now Jacket is working. But my NordVPN which I have 3 years subscription isn't working.
If I have to choose I would choose NordVPN to work because Sonarr can add RARBG as a tracker without Jackett, I won't have the other torrent sites.
Here is another result for Jackett
root@DietPi:~# tail -20 /opt/jackett/Jackett/log.txt
2019-06-23 21:32:45.5100 Info Loading Cardigann definition /opt/jackett/Definitions/sukebeinyaasi.yml
2019-06-23 21:32:45.5172 Info Loading Cardigann definition /opt/jackett/Definitions/gaytorrentru.yml
2019-06-23 21:32:45.5283 Info Loading Cardigann definition /opt/jackett/Definitions/zamundanet.yml
2019-06-23 21:32:45.5387 Info Loading Cardigann definition /opt/jackett/Definitions/hdchina.yml
2019-06-23 21:32:45.5509 Info Loading Cardigann definition /opt/jackett/Definitions/torrentslocal.yml
2019-06-23 21:32:45.6744 Info Loading Cardigann definition /opt/jackett/Definitions/mteamtp.yml
2019-06-23 21:32:45.6867 Info Loading Cardigann definition /opt/jackett/Definitions/p2pbg.yml
2019-06-23 21:32:45.7021 Info Loading Cardigann definition /opt/jackett/Definitions/bithumen.yml
2019-06-23 21:32:45.7133 Info Loading Cardigann definition /opt/jackett/Definitions/hdbitscom.yml
2019-06-23 21:32:45.7190 Info Loading Cardigann definition /opt/jackett/Definitions/mvgroupmain.yml
2019-06-23 21:32:45.7273 Info Loading Cardigann definition /opt/jackett/Definitions/diablotorrent.yml
2019-06-23 21:32:45.7381 Info Loading Cardigann definition /opt/jackett/Definitions/nethd.yml
2019-06-23 21:32:45.7442 Info Loading Cardigann definition /opt/jackett/Definitions/chdbits.yml
2019-06-23 21:32:45.7510 Info Loading Cardigann definition /opt/jackett/Definitions/tapochek.yml
2019-06-23 21:32:45.8229 Info Loading Cardigann definition /opt/jackett/Definitions/insanetracker.yml
2019-06-23 21:32:45.8334 Info Loading Cardigann definition /opt/jackett/Definitions/sktorrent.yml
2019-06-23 21:32:45.8462 Info Loading Cardigann definition /opt/jackett/Definitions/gfxnews.yml
2019-06-23 21:32:45.8890 Info Adding aggregate indexer
2019-06-23 21:32:46.2767 Warn No XML encryptor configured. Key {ac545dcb-bb84-4ef1-84e3-c4dfb0f4ff7c} may be persisted to storage in unencrypted form.
canabino
Post by canabino »
@MichaIng
Everything is working now, Jackett and NordVPN :D ;)
On RADXA's site, there was a new community created image, I just converted it to a DietPi system and everything is working.
Would you like me to create the system image from the community created image? or their Debian or Armbian?
