Jackett not working?
finch_6
Re: Jackett not working?
Post by finch_6 »
@MichaIng
So here is the results I get when I do:
journalctl --no-pager -u  jackett
Problem is, this goes on for so many characters, I can't post it (its ±600,000 characters nd I can only post 60,000), so this is just for May the 27th for 5mins, the next time stamp is from 16:49:xx, so Im sure this is a repeat error. However, if youu need me to post the rest of it I will just make many entries??
-- Logs begin at Mon 2019-05-27 16:07:05 BST, end at Tue 2019-05-28 10:43:24 BST. --
May 27 16:07:19 DietPi systemd[1]: Started Jackett Daemon (DietPi).
May 27 16:07:25 DietPi jackett[884]: 05-27 16:07:25 Info Starting Jackett v0.11.375.0
May 27 16:07:33 DietPi jackett[884]: 05-27 16:07:33 Info Environment version: 4.0.30319.42000 (/opt/jackett/)
May 27 16:07:33 DietPi jackett[884]: 05-27 16:07:33 Info OS version: Unix 4.19.42.7
May 27 16:07:33 DietPi jackett[884]: 05-27 16:07:33 Info Jackett variant: CoreLinuxArm32
May 27 16:07:33 DietPi jackett[884]: 05-27 16:07:33 Info ThreadPool MaxThreads: 32767 workerThreads, 1000 completionPortThreads
May 27 16:07:33 DietPi jackett[884]: 05-27 16:07:33 Info App config/log directory: /opt/jackett/Jackett
May 27 16:07:33 DietPi jackett[884]: 05-27 16:07:33 Info issue: Raspbian GNU/Linux 9 \n \l
May 27 16:07:33 DietPi jackett[884]: 05-27 16:07:33 Info Using HTTP Client: HttpWebClient2NetCore
May 27 16:07:37 DietPi jackett[884]: 05-27 16:07:37 Info Loading Cardigann definitions from: /opt/jackett/cardigann/definitions/, /etc/xdg/cardigan/definitions/, /opt/jackett/Definitions
May 27 16:07:38 DietPi jackett[884]: 05-27 16:07:38 Info Loading Cardigann definition /opt/jackett/Definitions/empornium.yml
May 27 16:07:38 DietPi jackett[884]: 05-27 16:07:38 Info Loading Cardigann definition /opt/jackett/Definitions/datascene.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/torrent9.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/world-of-tomorrow.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/torrentfunk.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/gktorrent.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/inperil.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/polishsource.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/elitetorrent-biz.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/hush.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/theshow.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/pt99.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/acgrip.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/icetorrent.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/hd4free.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/cpasbienclone.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/cartoonchaos.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/anidex.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/torrentkitty.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/theempire.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/3dtorrents.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/btkitty.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/worldofp2p.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/myspleen.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/prostylex.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/pwtorrents.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/speed-share.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/retroflix.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/zamundanet.yml
May 27 16:07:39 DietPi jackett[884]: 05-27 16:07:39 Info Loading Cardigann definition /opt/jackett/Definitions/thehorrorcharnel.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/trezzor.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/takeabyte.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/concen.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/bithumen.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/monova.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/hdhome.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/carpathians.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/arenabg.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/hdtorrentsit.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/gfxpeers.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/p2pbg.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/ccfbits.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/btdigg.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/torrenting.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/gfxnews.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/alein.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/film-paleis.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/tenyardtracker.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/nostalgic.yml
May 27 16:07:40 DietPi jackett[884]: 05-27 16:07:40 Info Loading Cardigann definition /opt/jackett/Definitions/zelkaorg.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/torrentbd.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/unionfansub.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/pthome.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/kinozal.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/cinefilhd.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/torrentland.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/sharespacedb.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/torrentlt.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/crnaberza.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/cinematik.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/Bittorrentfiles.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/asiandvdclub.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/sukebei-pantsu.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/cztorrent.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/nyoo.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/gay-torrents.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/scenefz.yml
May 27 16:07:41 DietPi jackett[884]: 05-27 16:07:41 Info Loading Cardigann definition /opt/jackett/Definitions/divteam.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/dragonworldreloaded.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/ztracker.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/elitehd.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/passionetorrent.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/b2s-share.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/btnext.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/tokyotosho.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/speedtorrentreloaded.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/bluebird.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/femdomcult.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/shellife.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/racing4everyone.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/limetorrents.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/metaltracker.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/sukebeinyaasi.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/hdbits.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/hdbitscom.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/majomparade.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/eztv.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/xtremezone.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/extratorrent-ag.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/gdf76.yml
May 27 16:07:42 DietPi jackett[884]: 05-27 16:07:42 Info Loading Cardigann definition /opt/jackett/Definitions/xbytes2.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/kapaki.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/gay-torrentsorg.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/casstudiotv.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/hdme.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/hdcity.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/classix.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/vanila.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/1337x.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/torlock.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/gaytorrentru.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/insanetracker.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/documentarytorrents.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/bitspyder.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/deildu.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/bigtower.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/kickasstorrent.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/cpabien.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/torviet.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/casatorrent.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/hdforever.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/yourexotic.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/tigers-dl.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/efectodoppler.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/asiancinema.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/bitme.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/theshinning.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/sdbits.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/estone.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/linkomanija.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/racingforme.yml
May 27 16:07:43 DietPi jackett[884]: 05-27 16:07:43 Info Loading Cardigann definition /opt/jackett/Definitions/elittracker.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/vizuk.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/audionews.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/x-ite.me.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/proaudiotorrents.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/dreamteam.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/nethd.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/ilcorsaroblu.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/torrentdownloads.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/rodvd.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/DasUnerwartete.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/karagarga.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/chdbits.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/scenerush.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/freetorrent.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/audiobookbay.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/katcrs.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/channelx.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/manicomioshare.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/ast4u.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/btdb.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/losslessclub.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/uhdbits.yml
May 27 16:07:44 DietPi jackett[884]: 05-27 16:07:44 Info Loading Cardigann definition /opt/jackett/Definitions/nnm-club.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/soundpark.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/greekteam.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/blutopia.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/sportscult.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/nyaa-pantsu.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/desitorrents.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/trancetraffic.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/hdspain.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/hdarea.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/bit-titan.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/mononokebt.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/hdsky.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/awesomehd.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/beyond-hd.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/iloveclassics.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/isohunt2.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/uniongang.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/girotorrent.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/hqsource.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/mvgroupmain.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/torrentproject2.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/skytorrentsclone.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/solidtorrents.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/kikibt.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/rgu.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/xwtorrents.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/hdchina.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/nyaasi.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/kickasstorrent-kathow.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/metal-iplay-ro.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/btgigs.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/downloadville.yml
May 27 16:07:45 DietPi jackett[884]: 05-27 16:07:45 Info Loading Cardigann definition /opt/jackett/Definitions/thepiratebay.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/fullmixmusic.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/rockethd.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/diablotorrent.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/desireleasers.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/ethor.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/mactorrents.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/funkytorrents.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/ultimategamerclub.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/hon3yhd.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/puntotorrent.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/amigosshare.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/qxr.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/zooqle.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/sharewood.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/bithorlo.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/avg.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/magico.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/totheglory.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/audiobooktorrents.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/tntvillage.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/generationfree.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/redstartorrent.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/scenereactor.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/worldwidetorrents.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/newretro.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/aox.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/fanoin.yml
May 27 16:07:46 DietPi jackett[884]: 05-27 16:07:46 Info Loading Cardigann definition /opt/jackett/Definitions/tapochek.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/waffles.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/dxdhd.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/torrentslocal.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/arabafenice.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/aftershock.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/rutor.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/hachede.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/acidlounge.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/ourbits.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/newstudio.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/mteamtp.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/jpopsuki.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/torrent9clone.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/xktorrent.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/rockbox.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/ilcorsaronero.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/torrentseeds.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/peersfm.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/hyperay.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/sporthd.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/bitturk.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/cinemageddon.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/ptfiles.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/mvgroupforum.yml
May 27 16:07:47 DietPi jackett[884]: 05-27 16:07:47 Info Loading Cardigann definition /opt/jackett/Definitions/piratbit.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/dark-shadow.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/siambit.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/torrentz2.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/digbt.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/totallykids.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/spacetorrent.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/hdcenter.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/torrentccf.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/bigtorrent.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/pleasuredome.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/turktorrent.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/anirena.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/gigatorrents.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/backups.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/teamhd.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/frozenlayer.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/2fast4you.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/tasmanit.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/wihd.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/sktorrent.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/torrent-turk.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/theplace.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/focusx.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/shokweb.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/yggtorrent.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/theoccult.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/thetorrents.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/shareisland.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/btbit.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/lesaloon.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/ettv.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/torrentsectorcrew.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/thegeeks.yml
May 27 16:07:48 DietPi jackett[884]: 05-27 16:07:48 Info Loading Cardigann definition /opt/jackett/Definitions/thevault.yml
May 27 16:07:49 DietPi jackett[884]: 05-27 16:07:49 Info Loading Cardigann definition /opt/jackett/Definitions/megabliz.yml
May 27 16:07:49 DietPi jackett[884]: 05-27 16:07:49 Info Loading Cardigann definition /opt/jackett/Definitions/torrenthr.yml
May 27 16:07:49 DietPi jackett[884]: 05-27 16:07:49 Info Loading Cardigann definition /opt/jackett/Definitions/torrentgalaxyorg.yml
May 27 16:07:49 DietPi jackett[884]: 05-27 16:07:49 Info Loading Cardigann definition /opt/jackett/Definitions/3evils.yml
May 27 16:07:49 DietPi jackett[884]: 05-27 16:07:49 Info Loading Cardigann definition /opt/jackett/Definitions/tbplus.yml
May 27 16:07:49 DietPi jackett[884]: 05-27 16:07:49 Info Adding aggregate indexer
May 27 16:07:52 DietPi jackett[884]: Hosting environment: Production
May 27 16:07:52 DietPi jackett[884]: Content root path: /opt/jackett/Content
May 27 16:07:52 DietPi jackett[884]: Now listening on: http://[::]:9117
May 27 16:07:52 DietPi jackett[884]: Application started. Press Ctrl+C to shut down.
May 27 16:08:36 DietPi jackett[884]: 05-27 16:08:36 Error System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types.
May 27 16:08:36 DietPi jackett[884]: Could not load file or assembly 'Microsoft.CodeAnalysis.CSharp, Version=2.8.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. The module was expected to contain an assembly manifest.
May 27 16:08:36 DietPi jackett[884]:    at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
May 27 16:08:36 DietPi jackett[884]:    at System.Reflection.RuntimeAssembly.get_DefinedTypes()
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.ApplicationParts.AssemblyPart.get_Types()
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Controllers.ControllerFeatureProvider.PopulateFeature(IEnumerable`1 parts, ControllerFeature feature)
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.ApplicationParts.ApplicationPartManager.PopulateFeature[TFeature](TFeature feature)
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionDescriptorProvider.GetControllerTypes()
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionDescriptorProvider.BuildModel()
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionDescriptorProvider.GetDescriptors()
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionDescriptorProvider.OnProvidersExecuting(ActionDescriptorProviderContext context)
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Infrastructure.DefaultActionDescriptorCollectionProvider.UpdateCollection()
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Infrastructure.DefaultActionDescriptorCollectionProvider.Initialize()
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Infrastructure.DefaultActionDescriptorCollectionProvider.get_ActionDescriptors()
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.AttributeRoute.GetTreeRouter()
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.AttributeRoute.RouteAsync(RouteContext context)
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Routing.RouteCollection.RouteAsync(RouteContext context)
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Builder.RouterMiddleware.Invoke(HttpContext httpContext)
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
May 27 16:08:36 DietPi jackett[884]:    at Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware.Invoke(HttpContext context)
May 27 16:08:36 DietPi jackett[884]:    at Jackett.Server.Middleware.CustomExceptionHandler.Invoke(HttpContext httpContext) in /home/appveyor/projects/jackett/src/Jackett.Server/Middleware/CustomExceptionHandler.cs:line 29
May 27 16:08:36 DietPi jackett[884]: System.BadImageFormatException: Could not load file or assembly 'Microsoft.CodeAnalysis.CSharp, Version=2.8.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. The module was expected to contain an assembly manifest.
May 27 16:08:36 DietPi jackett[884]: File name: 'Microsoft.CodeAnalysis.CSharp, Version=2.8.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
May 27 16:08:36 DietPi jackett[884]:  System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types.
May 27 16:14:11 DietPi jackett[884]: 05-27 16:14:11 Error System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types.
May 27 16:14:11 DietPi jackett[884]: Could not load file or assembly 'Microsoft.CodeAnalysis.CSharp, Version=2.8.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. The module was expected to contain an assembly manifest.
May 27 16:14:11 DietPi jackett[884]:    at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
May 27 16:14:11 DietPi jackett[884]:    at System.Reflection.RuntimeAssembly.get_DefinedTypes()
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.ApplicationParts.AssemblyPart.get_Types()
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Controllers.ControllerFeatureProvider.PopulateFeature(IEnumerable`1 parts, ControllerFeature feature)
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.ApplicationParts.ApplicationPartManager.PopulateFeature[TFeature](TFeature feature)
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionDescriptorProvider.GetControllerTypes()
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionDescriptorProvider.BuildModel()
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionDescriptorProvider.GetDescriptors()
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionDescriptorProvider.OnProvidersExecuting(ActionDescriptorProviderContext context)
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Infrastructure.DefaultActionDescriptorCollectionProvider.UpdateCollection()
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Infrastructure.DefaultActionDescriptorCollectionProvider.Initialize()
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Infrastructure.DefaultActionDescriptorCollectionProvider.get_ActionDescriptors()
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.AttributeRoute.GetTreeRouter()
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Mvc.Internal.AttributeRoute.RouteAsync(RouteContext context)
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Routing.RouteCollection.RouteAsync(RouteContext context)
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Builder.RouterMiddleware.Invoke(HttpContext httpContext)
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
May 27 16:14:11 DietPi jackett[884]:    at Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware.Invoke(HttpContext context)
May 27 16:14:11 DietPi jackett[884]:    at Jackett.Server.Middleware.CustomExceptionHandler.Invoke(HttpContext httpContext) in /home/appveyor/projects/jackett/src/Jackett.Server/Middleware/CustomExceptionHandler.cs:line 29
May 27 16:14:11 DietPi jackett[884]: System.BadImageFormatException: Could not load file or assembly 'Microsoft.CodeAnalysis.CSharp, Version=2.8.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. The module was expected to contain an assembly manifest.
May 27 16:14:11 DietPi jackett[884]: File name: 'Microsoft.CodeAnalysis.CSharp, Version=2.8.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
May 27 16:14:11 DietPi jackett[884]:  System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types.
And here is the result from
tail -20 /opt/jackett/Jackett/log.txt
root@DietPi:~# tail -20 /opt/jackett/Jackett/log.txt
Hope this helps??
Sorry it took so long to reply...
DietPi on a Raspberry Pi 3 B+ running:
- Sonarr
- Deluge
- Jackett
@finch_6 @deathisunknown
Ah I wasn't aware that indeed a reinstall is required and service restart is not sufficient to fix things.
Indeed after update there also seems to be something missing:
So possibly it is not the restart after update that breaks things, but indeed the update itself, at least now? Looks also like a .NET (Microsoft) specific error.
Looks like the auto-updater should be disabled for now. At least reinstall is not much hassle, especially without mono.
finch_6
Post by finch_6 »
@MichaIng
I haven’t tried the reinstall yet. Should I give it a bash..?
- Sonarr
- Deluge
- Jackett
noobian
Post by noobian »
@deathisunknown
Can you explain the command to me?
dietpi-software reinstall 147
What does the "147" stand for?
@noobian
147 is the DietPi-Software internal ID of Jackett. You can list all IDs with dietpi-software list.
reinstall is the CLI command to reinstall installed software. "install" or "uninstall" exist as well.
noobian
Post by noobian »
MichaIng wrote: Tue May 28, 2019 3:10 pm reinstall is the CLI command to reinstall installed software. "install" or "uninstall" exist as well.
thx for the explanation :)
Will a "reinstall" keep previous settings done in Jackett (like Indexers, API-String, etc)?
Or is it just a quicker way to reinstall (without uninstalling first)?
deathisunknown
Post by deathisunknown »
@noobian
Yes, a reinstall via dietpi-software should keep your settings, but use dietpi-backup if you are unsure. I've reinstalled many times with no loss of settings so far.
finch_6
Post by finch_6 »
@MichaIng
OK, so.....
I didn't do anything with regards to reinstalling or anything since it wasn't working!
Tried again now and Jackett is working...???? :? :? :?
- Sonarr
- Deluge
- Jackett
nobbysheep
Post by nobbysheep »
Also experiencing same issue. I've followed the step mentioned above (sudo dietpi-software reinstall 147) which seems to have worked.
canabino
Post by canabino »
Jackett isn't working even after reinstalling.
Reinstall comes up with errors Installing LibSSL1.0.0
root@DietPi:~# journalctl --no-pager -u  jackett
-- Logs begin at Thu 2019-05-30 20:34:46 -05, end at Thu 2019-05-30 21:19:15 -05. --
May 30 20:35:18 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:35:24 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:35:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:35:34 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:35:39 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:35:45 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:35:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:35:55 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:00 DietPi systemd[1642]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:36:00 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:06 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:16 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:21 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:27 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:37 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:42 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:48 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:53 DietPi systemd[1712]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:36:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:36:58 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:03 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:09 DietPi systemd[1739]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:37:09 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:19 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:24 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:30 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:40 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:45 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:51 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:37:56 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:01 DietPi systemd[1809]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:38:01 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:06 DietPi systemd[1817]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:38:06 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:12 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:22 DietPi systemd[1833]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:38:22 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:27 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:33 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:43 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:48 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:54 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:38:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:39:04 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:39:09 DietPi systemd[2264]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:39:09 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:39:15 DietPi systemd[2311]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:39:15 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:40:57 DietPi systemd[4755]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:40:57 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:02 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:08 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:13 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:18 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:23 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:34 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:39 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:44 DietPi systemd[5123]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:41:44 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:41:55 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:00 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:05 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:16 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:21 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:26 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:37 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:42 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:47 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:42:58 DietPi systemd[5207]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:42:58 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:03 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:08 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:19 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:24 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:29 DietPi systemd[5250]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:43:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:35 DietPi systemd[5255]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:43:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:40 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:45 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:43:56 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:01 DietPi systemd[5289]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:44:01 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:06 DietPi systemd[5294]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:44:06 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:17 DietPi systemd[5308]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:44:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:22 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:27 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:43 DietPi systemd[5372]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:44:43 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:48 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:44:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:04 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:09 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:20 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:25 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:30 DietPi systemd[5551]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:45:30 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:35 DietPi systemd[5556]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:45:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:41 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:46 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:51 DietPi systemd[5599]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:45:51 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:45:56 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:02 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:07 DietPi systemd[5614]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:46:07 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:12 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:23 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:28 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:33 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:44 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:49 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:54 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:46:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:05 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:10 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:15 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:20 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:26 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:31 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:36 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:41 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:47 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:52 DietPi systemd[5745]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:47:52 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:47:57 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:02 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:08 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:13 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:18 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:23 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:29 DietPi systemd[5787]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:48:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:34 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:39 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:44 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:50 DietPi systemd[5813]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:48:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:48:55 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:00 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:05 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:16 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:21 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:26 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:37 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:42 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:47 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:53 DietPi systemd[5883]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:49:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:49:58 DietPi systemd[5891]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:49:58 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:03 DietPi systemd[5896]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:50:03 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:08 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:19 DietPi systemd[5950]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:50:19 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:24 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:40 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:45 DietPi systemd[6036]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:50:45 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:50:56 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:01 DietPi systemd[6066]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:51:01 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:06 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:17 DietPi systemd[6086]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:51:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:22 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:27 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:43 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:48 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:51:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:04 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:09 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:20 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:25 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:30 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:41 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:46 DietPi systemd[6215]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:52:46 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:51 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:52:56 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:02 DietPi systemd[6232]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:53:02 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:07 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:12 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:17 DietPi systemd[6253]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:53:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:23 DietPi systemd[6258]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:53:23 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:28 DietPi systemd[6263]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:53:28 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:33 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:44 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:49 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:54 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:53:59 DietPi systemd[6298]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:53:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:05 DietPi systemd[6304]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:54:05 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:10 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:15 DietPi systemd[6319]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:54:15 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:20 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:26 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:31 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:36 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:41 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:47 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:52 DietPi systemd[6358]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:54:52 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:54:57 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:02 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:08 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:13 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:18 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:23 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:34 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:39 DietPi systemd[6412]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:55:39 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:44 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:55:55 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:00 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:05 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:11 DietPi systemd[6449]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:56:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:16 DietPi systemd[6457]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:56:16 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:21 DietPi systemd[6463]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:56:21 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:26 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:37 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:42 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:47 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:56:58 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:03 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:08 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:14 DietPi systemd[6522]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:57:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:19 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:24 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:35 DietPi systemd[6548]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:57:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:40 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:45 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:57:56 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:01 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:06 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:11 DietPi systemd[6588]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 20:58:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:22 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:27 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:43 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:48 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:58:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:59:04 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:59:09 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:59:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:59:20 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:59:25 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:59:30 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 20:59:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:07 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:12 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:23 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:28 DietPi systemd[9497]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:01:28 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:33 DietPi systemd[9503]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:01:33 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:44 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:49 DietPi systemd[9528]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:01:49 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:54 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:01:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:05 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:10 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:15 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:20 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:26 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:31 DietPi systemd[9581]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:02:31 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:36 DietPi systemd[9586]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:02:36 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:41 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:47 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:52 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:02:57 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:02 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:08 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:13 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:18 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:23 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:34 DietPi systemd[9658]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:03:34 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:39 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:44 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:03:55 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:00 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:05 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:16 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:21 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:26 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:37 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:42 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:47 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:04:58 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:03 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:08 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:19 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:24 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:40 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:45 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:05:56 DietPi systemd[9832]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:05:56 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:01 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:06 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:22 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:27 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:43 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:48 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:06:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:04 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:09 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:20 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:25 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:30 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:41 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:46 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:51 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:07:56 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:02 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:07 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:12 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:17 DietPi systemd[10005]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:08:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:23 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:28 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:33 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:44 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:49 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:54 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:08:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:09:05 DietPi systemd[10062]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:09:05 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:09:10 DietPi systemd[10067]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:09:10 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:09:15 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:09:20 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:09:26 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:09:31 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:09:36 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:09:41 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:01 DietPi systemd[12546]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:11:01 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:06 DietPi systemd[12822]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:11:06 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:12 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:22 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:27 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:33 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:43 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:48 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:54 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:11:59 DietPi systemd[12913]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:11:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:12:04 DietPi systemd[12918]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:12:04 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:12:09 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:12:14 DietPi systemd[13231]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:12:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:13:44 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:13:49 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:13:55 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:00 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:05 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:10 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:16 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:21 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:26 DietPi systemd[15783]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:14:26 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:31 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:37 DietPi systemd[15797]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:14:37 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:42 DietPi systemd[15802]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:14:42 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:47 DietPi systemd[15807]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:14:47 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:52 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:14:58 DietPi systemd[15821]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:14:58 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:03 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:08 DietPi systemd[15835]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:15:08 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:13 DietPi systemd[15840]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:15:13 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:19 DietPi systemd[15845]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:15:19 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:24 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:29 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:34 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:40 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:45 DietPi systemd[15875]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:15:45 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:50 DietPi systemd[15880]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:15:50 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:15:55 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:01 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:06 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:11 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:16 DietPi systemd[15913]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:16:16 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:22 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:27 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:32 DietPi systemd[15935]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:16:32 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:37 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:43 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:48 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:53 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:16:58 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:04 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:09 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:14 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:19 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:25 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:30 DietPi systemd[16062]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:17:30 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:35 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:40 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:46 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:51 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:17:56 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:01 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:07 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:12 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:17 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:22 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:28 DietPi systemd[16129]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:18:28 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:33 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:38 DietPi systemd[16140]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:18:38 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:43 DietPi systemd[16145]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:18:43 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:49 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:54 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:18:59 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:19:04 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:19:10 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
May 30 21:19:15 DietPi systemd[16191]: jackett.service: Failed at step EXEC spawning /opt/jackett/jackett: No such file or directory
May 30 21:19:15 DietPi systemd[1]: jackett.service: Failed with result 'exit-code'.
2019-05-31 09:01:53.2414 Info Loading Cardigann definition /opt/jackett/Definitions/unionfansub.yml
2019-05-31 09:01:53.2550 Info Loading Cardigann definition /opt/jackett/Definitions/vanila.yml
2019-05-31 09:01:53.2778 Info Loading Cardigann definition /opt/jackett/Definitions/vizuk.yml
2019-05-31 09:01:53.3054 Info Loading Cardigann definition /opt/jackett/Definitions/waffles.yml
2019-05-31 09:01:53.3352 Info Loading Cardigann definition /opt/jackett/Definitions/wihd.yml
2019-05-31 09:01:53.3900 Info Loading Cardigann definition /opt/jackett/Definitions/world-of-tomorrow.yml
2019-05-31 09:01:53.5811 Info Loading Cardigann definition /opt/jackett/Definitions/worldofp2p.yml
2019-05-31 09:01:53.6999 Info Loading Cardigann definition /opt/jackett/Definitions/worldwidetorrents.yml
2019-05-31 09:01:53.9727 Info Loading Cardigann definition /opt/jackett/Definitions/x-ite.me.yml
2019-05-31 09:01:54.0621 Info Loading Cardigann definition /opt/jackett/Definitions/xbytes2.yml
2019-05-31 09:01:54.2128 Info Loading Cardigann definition /opt/jackett/Definitions/xktorrent.yml
2019-05-31 09:01:54.3109 Info Loading Cardigann definition /opt/jackett/Definitions/xtremezone.yml
2019-05-31 09:01:54.4172 Info Loading Cardigann definition /opt/jackett/Definitions/xwtorrents.yml
2019-05-31 09:01:54.6362 Info Loading Cardigann definition /opt/jackett/Definitions/yggtorrent.yml
2019-05-31 09:01:54.8162 Info Loading Cardigann definition /opt/jackett/Definitions/yourexotic.yml
2019-05-31 09:01:54.9631 Info Loading Cardigann definition /opt/jackett/Definitions/zamundanet.yml
2019-05-31 09:01:55.0232 Info Loading Cardigann definition /opt/jackett/Definitions/zelkaorg.yml
2019-05-31 09:01:55.0874 Info Loading Cardigann definition /opt/jackett/Definitions/zooqle.yml
2019-05-31 09:01:55.1493 Info Loading Cardigann definition /opt/jackett/Definitions/ztracker.yml
2019-05-31 09:01:55.2683 Info Adding aggregate indexer
Any help is apreciated
