VPN client for DietPi Topic is solved
przemko
Re: VPN client for DietPi
Post by przemko »
OK, I read about that. One more time thank You for Your time.
Regards Przemek
WarHawk
Post by WarHawk »
JRaducha wrote: Tue May 28, 2019 8:27 am OK… I figured out how to get OpenVPN Client setup for DietPi.
Step 1
Set up your OpenVPN Server
Step 2
Login as root on to your DietPi
Step 3 Type-
apt-get update
Step 4 Type-
apt-get install openvpn
Step 5 – Configure the OpenVPN Client
In /etc/openvpn/ create a new text file named – (Your sever name).ovpn
Paste this text in - PLEASE MAKE CHANGES-----
## How to setup OpenVPN client?
## 1. Install OpenVPN software on your platform.
## 2. Double click XXXX.ovpn file to create new connection profile.
## 3. Type username and password while connection.
client
dev tun
script-security 3
remote (YOUR IP ADDRESS X.X.X.X) 1194
resolv-retry infinite
nobind
auth-nocache
auth-user-pass
remote-cert-tls server
reneg-sec 0
cipher AES-128-CBC
tls-cipher TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384:TLS-ECDHE-ECDSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA256:TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-RSA-WITH-AES-128-CBC-SHA
comp-lzo
proto udp
explicit-exit-notify 1
<ca>
-----BEGIN CERTIFICATE-----
(THIS IS LOCATED ON YOUR SERVER CALLED YOURSERVERNAME.CA)
-----END CERTIFICATE-----
</ca>
Step 6
Copy your CA from the server to the client
On the client - located at - /etc/openvpn/client/
Step 7 Type-
service openvpn restart
Step 8 (Just to make sure you have connectivity on both sides)
On the client, try and ping your server
Step 9 Type-
openvpn --config clientname.ovpn
Step 10
Enter your user name and password
Step 11
When OpenVPN shows the message “Initialization Sequence Completed“, then you are connected.
Very nice!!!!!!!
BrunoA
Post by BrunoA »
Step 1
Step 2
Step 3 Type-
apt-get update
Step 4 Type-
## 1. Install Surfshark VPN software on your platform.
client
dev tun
script-security 3
nobind
auth-nocache
auth-user-pass
reneg-sec 0
cipher AES-128-CBC
comp-lzo
proto udp
<ca>
</ca>
Step 6
Step 7 Type-
Step 9 Type-
Step 10
Step 11
This is exactly was I was looking for, thanks!
