VPN client for DietPi Topic is solved
Re: VPN client for DietPi
ok but something seems to be wrong around line 17 on your conf file
Unrecognized option or missing or extra parameter(s) in /etc/openvpn/dietpi.conf:17
przemko
Post by przemko »
That's it:
setenv opt block-outside-dns # Prevent Windows 10 DNS leak
I have similar situation when Libreelec installed on Rpi4. I delete that line but don't help.
can you check on OpenVPN Logs for further error messages.
przemko
Post by przemko »
I cannot find any openvpn log file but I have in ssh terminal still apearing messeges:
Broadcast message from root@DietPi (Tue 2020-03-24 15:38:38 CET):
Password entry required for 'Enter Private Key Password:' (PID 8108).
Please enter password with the systemd-tty-ask-password-agent tool:
Broadcast message from root@DietPi (Tue 2020-03-24 15:40:13 CET):
Password entry required for 'Enter Private Key Password:' (PID 8203).
Broadcast message from root@DietPi (Tue 2020-03-24 15:41:48 CET):
Password entry required for 'Enter Private Key Password:' (PID 8230).
Broadcast message from root@DietPi (Tue 2020-03-24 15:43:24 CET):
Password entry required for 'Enter Private Key Password:' (PID 8254).
^C
dietpi@DietPi:/var/log$ ls
alternatives.log  apt  btmp  dietpi-move_userdata.log  dpkg.log  fail2ban.log  lastlog	letsencrypt  lighttpd  mysql  php7.3-fpm.log  private  proftpd	redis  wtmp
Broadcast message from root@DietPi (Tue 2020-03-24 15:44:59 CET):
Password entry required for 'Enter Private Key Password:' (PID 8299).
I think it's because the first file dietpi.ovpn I create. That file was password protected. Second file with the same name dietpi.ovpn was without password but messeges still appear.
probably you can create a new file with with complete different name. and to clean everything, do a reboot before.
przemko
Post by przemko »
Can You tell if I will install PiVP or openvpn server on my Dietpi how it will work? Do I will get some different IP than my Public IP?
przemko
Post by przemko »
Joulinar wrote: Tue Mar 24, 2020 3:51 pm probably you can create a new file with with complete different name. and to clean everything, do a reboot before.
Can You tell me how to clean openvpn configuration? I delete file dietpi.conf and dietpi.ovpn
trendy
Post by trendy »
Did you add password in the private key?
przemko
Post by przemko »
OK, I create new file and now it works. I see I use my VPN but now my ...ddns.net/nextcloud stop working. Can this work together?
trendy
Post by trendy »
I am not familiar with ddns.net/nextcloud, but I suspect that you are redirecting all traffic to the VPN and these applications don't work when they are behind VPN. Is that so?
