Automated installation failing on "connection test" Topic is solved
k-plan
Re: Automated installation failing on "connection test"
Post by k-plan »
which image did you use? DietPi_RPi-armv6-(Jessie) or DietPi_RPi-armv6-(Wheezy) ?
Whats did Network Options: Adapters shows in dietpi-config ?
What happens, when you hit "Scan and connect"
scan
scan
Scan and connect
Scan and connect
On which wifi channel runs your accesspoint/wifi-router ?
WiFi country code is set ?
Output from:
lsusb
cat /etc/network/interfaces
tohax
Post by tohax »
I am using DietPi_RPi-armv6-(Jessie). When i hit "Scan and connect" it find my ssid, then i enter password, and during network service restarting i get errors (NETLINK: error: invalid argument) and network is not working. If i choose DHCP then "scan and connect" and continue, i am getting IP address and other parameters, and network start working. But i need static network parameters applying during 1st boot. I think, that set WiFi country code is not necessary(am i wrong?) i tried set it up to RU and US, but it is not solve the problem. I have TP-Link 1043 nd v1 router with openwrt. WiFi working on 11 channel. but i tried others - no result. Do you have jessie v127 image? Because on v127 ALL working fine. Maybe new kernel is the problem or drivers for RTL8192?(my wifi adapter) Thanks for your help!
k-plan
Post by k-plan »
thanks tohax for reporting this :!:
Testing with:
- RPi B+
- image: DietPi_v130_RPi-armv6-(Jessie).img
- changes in dietpi.txt
Ethernet_Enabled=0
Wifi_Enabled=1
Use_Static=1
AUTO_Install_Enable=1
wifi_country_code=DE
- wifi adapter (chipset - Realtek 8192cu ):
:~# lsusb
Bus 001 Device 005: ID 7392:7822 Edimax Technology Co., Ltd
:~# lsmod
Module                  Size  Used by
brcmfmac              201814  0
brcmutil                9031  1 brcmfmac
8192cu                597488  0
evdev                  11650  0
cfg80211              499234  2 brcmfmac,8192cu
rfkill                 21397  2 cfg80211
bcm2835_gpiomem         3823  0
bcm2835_wdt             4133  0
uio_pdrv_genirq         3718  0
uio                    10230  1 uio_pdrv_genirq
fuse                   90152  1
ipv6                  367575  14
Result:
- booting up with static IP on wifi and disabled ethernet ==>> no IP address, no IP connection
- switching via dietpi-config to DHCP ==>> IP address and IP connection will work
:~# uname -a
Linux RPi-B 4.4.19+ #907 Tue Sep 6 13:45:45 BST 2016 armv6l GNU/Linux
dmesg output while switching form DHCP => static IP
[   16.149262] cfg80211: Regulatory domain changed to country: DE
[   16.149305] cfg80211:  DFS Master region: ETSI
[   16.149320] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   16.149343] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   16.149361] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   16.149382] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   16.149399] cfg80211:   (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[   16.149415] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   18.566603] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  126.235856] ------------[ cut here ]------------
[  126.236834] WARNING: CPU: 0 PID: 6 at net/wireless/sme.c:907 __cfg80211_disconnected+0x280/0x2c8 [cfg80211]()
[  126.236943] Modules linked in: 8192cu evdev cfg80211 rfkill bcm2835_gpiomem bcm2835_wdt uio_pdrv_genirq uio fuse ipv6
[  126.237010] CPU: 0 PID: 6 Comm: kworker/u2:0 Not tainted 4.4.19+ #907
[  126.237023] Hardware name: BCM2708
[  126.237819] Workqueue: cfg80211 cfg80211_event_work [cfg80211]
[  126.237974] [<c0016cfc>] (unwind_backtrace) from [<c0013c20>] (show_stack+0x20/0x24)
[  126.238013] [<c0013c20>] (show_stack) from [<c02e38fc>] (dump_stack+0x20/0x28)
[  126.238044] [<c02e38fc>] (dump_stack) from [<c0021eb4>] (warn_slowpath_common+0x8c/0xc4)
[  126.238069] [<c0021eb4>] (warn_slowpath_common) from [<c0021fa8>] (warn_slowpath_null+0x2c/0x34)
[  126.238872] [<c0021fa8>] (warn_slowpath_null) from [<bf0e6b84>] (__cfg80211_disconnected+0x280/0x2c8 [cfg80211])
[  126.240106] [<bf0e6b84>] (__cfg80211_disconnected [cfg80211]) from [<bf0c20ac>] (cfg80211_process_wdev_events+0x1a0/0x20c [cfg80211])
[  126.241303] [<bf0c20ac>] (cfg80211_process_wdev_events [cfg80211]) from [<bf0c2154>] (cfg80211_process_rdev_events+0x3c/0x74 [cfg80211])
[  126.242820] [<bf0c2154>] (cfg80211_process_rdev_events [cfg80211]) from [<bf0bd208>] (cfg80211_event_work+0x24/0x2c [cfg80211])
[  126.243498] [<bf0bd208>] (cfg80211_event_work [cfg80211]) from [<c0037540>] (process_one_work+0x11c/0x39c)
[  126.243535] [<c0037540>] (process_one_work) from [<c0037800>] (worker_thread+0x40/0x4d0)
[  126.243566] [<c0037800>] (worker_thread) from [<c003d184>] (kthread+0xdc/0xf8)
[  126.243604] [<c003d184>] (kthread) from [<c000f8a8>] (ret_from_fork+0x14/0x2c)
[  126.243620] ---[ end trace 22f719d6d6b64ab0 ]---
[  126.775192] usbcore: registered new interface driver brcmfmac
[  132.000263] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  134.346639] cfg80211: Regulatory domain changed to country: DE
[  134.346682] cfg80211:  DFS Master region: ETSI
[  134.346696] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[  134.346716] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[  134.346732] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[  134.346747] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[  134.346760] cfg80211:   (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[  134.346772] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[  135.715603] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  168.261838] ------------[ cut here ]------------
[  168.262769] WARNING: CPU: 0 PID: 62 at net/wireless/sme.c:907 __cfg80211_disconnected+0x280/0x2c8 [cfg80211]()
[  168.262795] Modules linked in: brcmfmac brcmutil 8192cu evdev cfg80211 rfkill bcm2835_gpiomem bcm2835_wdt uio_pdrv_genirq uio fuse ipv6
[  168.262859] CPU: 0 PID: 62 Comm: kworker/u2:2 Tainted: G        W       4.4.19+ #907
[  168.262870] Hardware name: BCM2708
[  168.263558] Workqueue: cfg80211 cfg80211_event_work [cfg80211]
[  168.263872] [<c0016cfc>] (unwind_backtrace) from [<c0013c20>] (show_stack+0x20/0x24)
[  168.263909] [<c0013c20>] (show_stack) from [<c02e38fc>] (dump_stack+0x20/0x28)
[  168.263943] [<c02e38fc>] (dump_stack) from [<c0021eb4>] (warn_slowpath_common+0x8c/0xc4)
[  168.263968] [<c0021eb4>] (warn_slowpath_common) from [<c0021fa8>] (warn_slowpath_null+0x2c/0x34)
[  168.264817] [<c0021fa8>] (warn_slowpath_null) from [<bf0e6b84>] (__cfg80211_disconnected+0x280/0x2c8 [cfg80211])
[  168.266073] [<bf0e6b84>] (__cfg80211_disconnected [cfg80211]) from [<bf0c20ac>] (cfg80211_process_wdev_events+0x1a0/0x20c [cfg80211])
[  168.267319] [<bf0c20ac>] (cfg80211_process_wdev_events [cfg80211]) from [<bf0c2154>] (cfg80211_process_rdev_events+0x3c/0x74 [cfg80211])
[  168.268812] [<bf0c2154>] (cfg80211_process_rdev_events [cfg80211]) from [<bf0bd208>] (cfg80211_event_work+0x24/0x2c [cfg80211])
[  168.269651] [<bf0bd208>] (cfg80211_event_work [cfg80211]) from [<c0037540>] (process_one_work+0x11c/0x39c)
[  168.269696] [<c0037540>] (process_one_work) from [<c0037800>] (worker_thread+0x40/0x4d0)
[  168.269730] [<c0037800>] (worker_thread) from [<c003d184>] (kthread+0xdc/0xf8)
[  168.269765] [<c003d184>] (kthread) from [<c000f8a8>] (ret_from_fork+0x14/0x2c)
[  168.269780] ---[ end trace 22f719d6d6b64ab1 ]---
[  173.915893] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Have create a github issue for this: https://github.com/Fourdee/DietPi/issues/515
Solution at the moment:
- only use DHCP for wifi
UPDATE
Testing again with same config but DietPi_v127_RPi-armv6-(Jessie).img
Result:
- booting up with static IP on wifi and disabled ethernet ==>> IP address and IP connection will work ==> auto-update to DietPi_v130
root@RPi-B:~# uname -a
Linux RPi-B 4.4.16+ #899 Thu Jul 28 12:36:19 BST 2016 armv6l GNU/Linux
... but the same annoying dmesg output:
[   11.871090] usbcore: registered new interface driver rtl8192cu
[   12.156795] cfg80211: Regulatory domain changed to country: DE
[   12.156838] cfg80211:  DFS Master region: ETSI
[   12.156854] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   12.156880] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   12.156901] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   12.156920] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   12.156937] cfg80211:   (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[   12.156952] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   13.973864] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   15.763437] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:126972k SSFS
[   15.897195] cfg80211: World regulatory domain updated:
[   15.897238] cfg80211:  DFS Master region: unset
[   15.897255] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   15.897279] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   15.897295] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   15.897311] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   15.897330] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   15.897349] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   15.897365] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   15.897382] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   15.897398] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   16.033289] cfg80211: Regulatory domain changed to country: DE
[   16.033331] cfg80211:  DFS Master region: ETSI
[   16.033347] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   16.033369] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   16.033392] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   16.033412] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   16.033429] cfg80211:   (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[   16.033445] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   18.447248] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   97.391629] ------------[ cut here ]------------
[   97.392608] WARNING: CPU: 0 PID: 6 at net/wireless/sme.c:907 __cfg80211_disconnected+0x280/0x2c8 [cfg80211]()
[   97.392633] Modules linked in: 8192cu evdev cfg80211 rfkill bcm2835_gpiomem bcm2835_wdt uio_pdrv_genirq uio fuse ipv6
[   97.392698] CPU: 0 PID: 6 Comm: kworker/u2:0 Not tainted 4.4.16+ #899
[   97.392710] Hardware name: BCM2708
[   97.393441] Workqueue: cfg80211 cfg80211_event_work [cfg80211]
[   97.393524] [<c0016c9c>] (unwind_backtrace) from [<c0013c20>] (show_stack+0x20/0x24)
[   97.393559] [<c0013c20>] (show_stack) from [<c02e359c>] (dump_stack+0x20/0x28)
[   97.393594] [<c02e359c>] (dump_stack) from [<c0021e54>] (warn_slowpath_common+0x8c/0xc4)
[   97.393619] [<c0021e54>] (warn_slowpath_common) from [<c0021f48>] (warn_slowpath_null+0x2c/0x34)
[   97.394371] [<c0021f48>] (warn_slowpath_null) from [<bf0e5b84>] (__cfg80211_disconnected+0x280/0x2c8 [cfg80211])
[   97.395652] [<bf0e5b84>] (__cfg80211_disconnected [cfg80211]) from [<bf0c10ac>] (cfg80211_process_wdev_events+0x1a0/0x20c [cfg80211])
[   97.397143] [<bf0c10ac>] (cfg80211_process_wdev_events [cfg80211]) from [<bf0c1154>] (cfg80211_process_rdev_events+0x3c/0x74 [cfg80211])
[   97.398609] [<bf0c1154>] (cfg80211_process_rdev_events [cfg80211]) from [<bf0bc208>] (cfg80211_event_work+0x24/0x2c [cfg80211])
[   97.399611] [<bf0bc208>] (cfg80211_event_work [cfg80211]) from [<c00374e0>] (process_one_work+0x11c/0x39c)
[   97.399656] [<c00374e0>] (process_one_work) from [<c00377a0>] (worker_thread+0x40/0x4d0)
[   97.399686] [<c00377a0>] (worker_thread) from [<c003d124>] (kthread+0xdc/0xf8)
[   97.399723] [<c003d124>] (kthread) from [<c000f8a8>] (ret_from_fork+0x14/0x2c)
[   97.399738] ---[ end trace f13b9e6ac140c28b ]---
[   97.933622] usbcore: registered new interface driver brcmfmac
[  103.180406] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  105.454529] cfg80211: World regulatory domain updated:
[  105.454574] cfg80211:  DFS Master region: unset
[  105.454589] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[  105.454610] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[  105.454625] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[  105.454639] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[  105.454653] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[  105.454670] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[  105.454683] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[  105.454696] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[  105.454710] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[  105.545701] cfg80211: Regulatory domain changed to country: DE
[  105.545742] cfg80211:  DFS Master region: ETSI
[  105.545756] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[  105.545777] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[  105.545793] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[  105.545812] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[  105.545825] cfg80211:   (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[  105.545838] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[  106.914932] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
tohax
Post by tohax »
Thank you very much! Waiting for v131 to come out
