Here is the update log :
[ OK ] DietPi-Update | wget https://raw.githubusercontent.com/MichaIng/DietPi/master/dietpi/pre-patch_file -O pre-patch_file
DietPi-Pre-patch
Mode: Applying pre-patches
[ OK ] Successfully applied pre-patches
[ INFO ] DietPi-Update | APT update, please wait...
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Hit:2 http://dev2day.de/pms stretch InRelease
Hit:4 https://archive.raspberrypi.org/debian stretch InRelease
Get:3 https://www.bchemnet.com/suldr debian InRelease [10.9 kB]
Ign:3 https://www.bchemnet.com/suldr debian InRelease
Fetched 25.8 kB in 1s (15.4 kB/s)
Reading package lists...
W: GPG error: https://www.bchemnet.com/suldr debian InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY FB510D557CC3E840
W: The repository 'http://www.bchemnet.com/suldr debian InRelease' is not signed.
[ OK ] DietPi-Update | G_AGUP
[ INFO ] DietPi-Update | APT upgrade, please wait...
[ OK ] DietPi-Update | G_AGUG
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 120 0 120 0 0 298 0 --:--:-- --:--:-- --:--:-- 299
100 2531k 100 2531k 0 0 1641k 0 0:00:01 0:00:01 --:--:-- 2436k
[ OK ] DietPi-Update | Unpack update archive
[ OK ] DietPi-Update | Copy DietPi core files to RAMdisk
[ OK ] DietPi-Update | Copy DietPi rootfs files in place
[ OK ] DietPi-Update | Set execute permissions for DietPi scripts
[ SUB1 ] DietPi-Set_software > verify_dietpi.txt ()
[ OK ] DietPi-Set_software | Connection test: https://raw.githubusercontent.com/MichaIng/DietPi/master/dietpi.txt
[ OK ] DietPi-Set_software | Patching dietpi.txt
[ OK ] DietPi-Set_software | Downloading current dietpi.txt
[ OK ] DietPi-Set_software | dietpi.txt verification completed
[ OK ] verify_dietpi.txt | Completed
DietPi-Update
Mode: Running incremental patching
[ INFO ] DietPi-Update | Current version : v6.22.3 (branch: Fourdee/master)
[ INFO ] DietPi-Update | Latest version : v6.24.1 (branch: MichaIng/master)
[ INFO ] DietPi-Update | Patching 6.22.3 to 6.23
[ OK ] DietPi-Patchfile | cp -a /etc/php /mnt/dietpi_userdata/php_bak
[ OK ] DietPi-Software | Initialised database
[ OK ] DietPi-Software | Reading database
[ SUB2 ] DietPi-Software > Automated reinstall
[ INFO ] DietPi-Software | 34: Subsonic is not currently installed
[ INFO ] DietPi-Software | The program must be installed, before reinstall can be used
[ OK ] DietPi-Software | No changes applied for: Subsonic
[ INFO ] DietPi-Software | 35: Logitech Media Server is not currently installed
[ OK ] DietPi-Software | No changes applied for: Logitech Media Server
[ INFO ] DietPi-Software | 42: Plex Media Server is not currently installed
[ OK ] DietPi-Software | No changes applied for: Plex Media Server
[ INFO ] DietPi-Software | 139: SABnzbd is not currently installed
[ OK ] DietPi-Software | No changes applied for: SABnzbd
[ INFO ] DietPi-Software | 147: Jackett is not currently installed
[ OK ] DietPi-Software | No changes applied for: Jackett
[ OK ] DietPi-Software | Reinstalling PHP: Hypertext Preprocessor for dynamic web content
[ OK ] DietPi-Software | Free space check: path=/ | available=54691 MiB | required=500 MiB
[ OK ] DietPi-Software | Connection test: http://raspbian.raspberrypi.org/raspbian
[ OK ] NTPD: time sync | Completed
[ SUB3 ] DietPi-Services > unmask
[ OK ] DietPi-Services | unmask all: avahi-daemon
[ OK ] DietPi-Services | unmask all: nmbd
[ OK ] DietPi-Services | unmask all: smbd
[ OK ] DietPi-Services | unmask all: redis-server
[ OK ] DietPi-Services | unmask all: mariadb
[ OK ] DietPi-Services | unmask all: php7.0-fpm
[ OK ] DietPi-Services | unmask all: lighttpd
[ OK ] DietPi-Services | unmask all: cups
[ OK ] DietPi-Services | unmask all: cloudprintd
[ OK ] DietPi-Services | unmask all: noip2
[ OK ] DietPi-Services | unmask all: webmin
[ OK ] DietPi-Services | unmask all: cron
[ SUB2 ] DietPi-Software > Update & upgrade APT
[ INFO ] DietPi-Software | APT update, please wait...
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:3 https://archive.raspberrypi.org/debian stretch InRelease
Get:2 https://www.bchemnet.com/suldr debian InRelease [10.9 kB]
Ign:2 https://www.bchemnet.com/suldr debian InRelease
Fetched 10.9 kB in 1s (6,700 B/s)
[ OK ] DietPi-Software | G_AGUP
[ INFO ] DietPi-Software | Running apt simulation to check for errors, please wait...
[ INFO ] DietPi-Software | APT installation for: bash-doc -s, please wait...
Inst bash-doc (4.4-5 Raspbian:stable [all])
Conf bash-doc (4.4-5 Raspbian:stable [all])
[ OK ] DietPi-Software | G_AGI bash-doc -s
[ INFO ] DietPi-Software | APT upgrade, please wait...
[ OK ] DietPi-Software | G_AGUG
[ SUB2 ] DietPi-Software > Checking for prerequisite software
[ SUB3 ] DietPi-Services > stop
[ OK ] DietPi-Services | stop : cron
[ OK ] DietPi-Services | stop : webmin
[ OK ] DietPi-Services | stop : noip2
[ OK ] DietPi-Services | stop : cloudprintd
[ OK ] DietPi-Services | stop : cups
[ OK ] DietPi-Services | stop : lighttpd
[ OK ] DietPi-Services | stop : php7.0-fpm
[ OK ] DietPi-Services | stop : mariadb
[ OK ] DietPi-Services | stop : redis-server
[ OK ] DietPi-Services | stop : smbd
[ OK ] DietPi-Services | stop : nmbd
[ OK ] DietPi-Services | stop : avahi-daemon
[ OK ] DietPi-Software | Connection test: https://packages.sury.org/php/apt.gpg
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
Get:3 https://packages.sury.org/php stretch InRelease [6,760 B]
Get:5 https://packages.sury.org/php stretch/main armhf Packages [110 kB]
Fetched 128 kB in 3s (38.6 kB/s)
[ INFO ] DietPi-Software | APT installation for: php7.3-fpm php7.3-apcu php7.3-curl php7.3-gd php7.3-mbstring php7.3-xml php7.3-zip php7.3-mysql php7.3-redis, please wait...
Extracting templates from packages: 100%
(Reading database ... 69855 files and directories currently installed.)
Preparing to unpack .../00-php-common_2%3a69+0~20190303094804.15+stretch~1.gbp0f7465_all.deb ...
Unpacking php-common (2:69+0~20190303094804.15+stretch~1.gbp0f7465) over (1:49) ...
Preparing to unpack .../01-libzip4_1.5.1-4+0~20190318173229.9+stretch~1.gbp333132_armhf.deb ...
Unpacking libzip4:armhf (1.5.1-4+0~20190318173229.9+stretch~1.gbp333132) over (1.1.2-1.1) ...
Preparing to unpack .../02-php7.0-zip_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-zip (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../03-php7.0-xml_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-xml (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../04-php7.0-readline_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-readline (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../05-php7.0-opcache_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-opcache (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../06-php7.0-mysql_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-mysql (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../07-php7.0-mcrypt_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-mcrypt (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../08-php7.0-mbstring_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-mbstring (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../09-php7.0-json_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-json (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Selecting previously unselected package libicu64:armhf.
Preparing to unpack .../10-libicu64_64.1-0.1+0~20190410090943.5+stretch~1.gbp38f694_armhf.deb ...
Unpacking libicu64:armhf (64.1-0.1+0~20190410090943.5+stretch~1.gbp38f694) ...
Preparing to unpack .../11-php7.0-intl_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-intl (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../12-php7.0-gd_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-gd (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../13-libpcre3_2%3a8.42-1+0~20190203125157.5+stretch~1.gbp79d75d_armhf.deb ...
Unpacking libpcre3:armhf (2:8.42-1+0~20190203125157.5+stretch~1.gbp79d75d) over (2:8.39-3) ...
Setting up libpcre3:armhf (2:8.42-1+0~20190203125157.5+stretch~1.gbp79d75d) ...
(Reading database ... 69872 files and directories currently installed.)
Preparing to unpack .../00-php7.0-cli_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-cli (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../01-php7.0-fpm_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-fpm (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../02-php7.0-curl_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-curl (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Preparing to unpack .../03-php7.0-common_7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff_armhf.deb ...
Unpacking php7.0-common (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) over (7.0.33-0+deb9u3) ...
Selecting previously unselected package php7.3-common.
Preparing to unpack .../04-php7.3-common_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-common (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package php7.3-json.
Preparing to unpack .../05-php7.3-json_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-json (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package php7.3-opcache.
Preparing to unpack .../06-php7.3-opcache_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-opcache (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package php7.3-readline.
Preparing to unpack .../07-php7.3-readline_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-readline (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package libargon2-1:armhf.
Preparing to unpack .../08-libargon2-1_0~20171227-1~20190119054414.2+stretch_armhf.deb ...
Unpacking libargon2-1:armhf (0~20171227-1~20190119054414.2+stretch) ...
Selecting previously unselected package libpcre2-8-0:armhf.
Preparing to unpack .../09-libpcre2-8-0_10.32-4+0~20190202200700.3+stretch~1.gbpd4ef41_armhf.deb ...
Unpacking libpcre2-8-0:armhf (10.32-4+0~20190202200700.3+stretch~1.gbpd4ef41) ...
Selecting previously unselected package libsodium23:armhf.
Preparing to unpack .../10-libsodium23_1.0.17-0.1+0~20190131101845.5+stretch~1.gbp8cf594_armhf.deb ...
Unpacking libsodium23:armhf (1.0.17-0.1+0~20190131101845.5+stretch~1.gbp8cf594) ...
Selecting previously unselected package php7.3-cli.
Preparing to unpack .../11-php7.3-cli_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-cli (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package php7.3-fpm.
Preparing to unpack .../12-php7.3-fpm_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-fpm (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Setting up php-common (2:69+0~20190303094804.15+stretch~1.gbp0f7465) ...
(Reading database ... 70017 files and directories currently installed.)
Preparing to unpack .../0-php-apcu_5.1.17+4.0.11-1+0~20190217111312.9+stretch~1.gbp192528_armhf.deb ...
find: ‘/etc/php/7.2’: No such file or directory
find: ‘/etc/php/7.1’: No such file or directory
find: ‘/etc/php/5.6’: No such file or directory
WARNING: Module apcu ini file doesn't exist under /etc/php/7.3/mods-available
Unpacking php-apcu (5.1.17+4.0.11-1+0~20190217111312.9+stretch~1.gbp192528) over (5.1.8+4.0.11-1) ...
Preparing to unpack .../1-php-redis_4.3.0-1+0~20190606080331.12+stretch~1.gbp0171a6_armhf.deb ...
WARNING: Module redis ini file doesn't exist under /etc/php/7.3/mods-available
Unpacking php-redis (4.3.0-1+0~20190606080331.12+stretch~1.gbp0171a6) over (3.1.1-1) ...
Selecting previously unselected package php7.3-curl.
Preparing to unpack .../2-php7.3-curl_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-curl (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package php7.3-gd.
Preparing to unpack .../3-php7.3-gd_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-gd (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package php7.3-mbstring.
Preparing to unpack .../4-php7.3-mbstring_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-mbstring (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package php7.3-mysql.
Preparing to unpack .../5-php7.3-mysql_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-mysql (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package php7.3-xml.
Preparing to unpack .../6-php7.3-xml_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-xml (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Selecting previously unselected package php7.3-zip.
Preparing to unpack .../7-php7.3-zip_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-zip (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Setting up php7.3-common (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/calendar.ini with new version
Creating config file /etc/php/7.3/mods-available/ctype.ini with new version
Creating config file /etc/php/7.3/mods-available/exif.ini with new version
Creating config file /etc/php/7.3/mods-available/fileinfo.ini with new version
Creating config file /etc/php/7.3/mods-available/ftp.ini with new version
Creating config file /etc/php/7.3/mods-available/gettext.ini with new version
Creating config file /etc/php/7.3/mods-available/iconv.ini with new version
Creating config file /etc/php/7.3/mods-available/pdo.ini with new version
Creating config file /etc/php/7.3/mods-available/phar.ini with new version
Creating config file /etc/php/7.3/mods-available/posix.ini with new version
Creating config file /etc/php/7.3/mods-available/shmop.ini with new version
Creating config file /etc/php/7.3/mods-available/sockets.ini with new version
Creating config file /etc/php/7.3/mods-available/sysvmsg.ini with new version
Creating config file /etc/php/7.3/mods-available/sysvsem.ini with new version
Creating config file /etc/php/7.3/mods-available/sysvshm.ini with new version
Creating config file /etc/php/7.3/mods-available/tokenizer.ini with new version
Setting up php7.3-curl (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/curl.ini with new version
Setting up libzip4:armhf (1.5.1-4+0~20190318173229.9+stretch~1.gbp333132) ...
Setting up php7.3-opcache (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/opcache.ini with new version
Setting up php7.3-xml (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/dom.ini with new version
Creating config file /etc/php/7.3/mods-available/simplexml.ini with new version
Creating config file /etc/php/7.3/mods-available/wddx.ini with new version
Creating config file /etc/php/7.3/mods-available/xml.ini with new version
Creating config file /etc/php/7.3/mods-available/xmlreader.ini with new version
Creating config file /etc/php/7.3/mods-available/xmlwriter.ini with new version
Creating config file /etc/php/7.3/mods-available/xsl.ini with new version
Setting up libsodium23:armhf (1.0.17-0.1+0~20190131101845.5+stretch~1.gbp8cf594) ...
Setting up php7.3-gd (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/gd.ini with new version
Processing triggers for libc-bin (2.24-11+deb9u4) ...
Setting up php7.3-mysql (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/mysqlnd.ini with new version
Creating config file /etc/php/7.3/mods-available/mysqli.ini with new version
Creating config file /etc/php/7.3/mods-available/pdo_mysql.ini with new version
Processing triggers for systemd (232-25+deb9u11) ...
Setting up php7.3-readline (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/readline.ini with new version
Setting up php7.0-common (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up libargon2-1:armhf (0~20171227-1~20190119054414.2+stretch) ...
Setting up libpcre2-8-0:armhf (10.32-4+0~20190202200700.3+stretch~1.gbpd4ef41) ...
Setting up php7.0-xml (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up libicu64:armhf (64.1-0.1+0~20190410090943.5+stretch~1.gbp38f694) ...
Setting up php7.0-mysql (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php7.3-zip (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/zip.ini with new version
Setting up php7.3-mbstring (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/mbstring.ini with new version
Setting up php7.0-readline (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php7.3-json (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/json.ini with new version
Setting up php7.0-opcache (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php7.0-mbstring (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php7.0-gd (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php7.0-mcrypt (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php7.0-curl (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php7.0-zip (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php7.3-cli (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
update-alternatives: using /usr/bin/php7.3 to provide /usr/bin/php (php) in auto mode
update-alternatives: using /usr/bin/phar7.3 to provide /usr/bin/phar (phar) in auto mode
update-alternatives: using /usr/bin/phar.phar7.3 to provide /usr/bin/phar.phar (phar.phar) in auto mode
Creating config file /etc/php/7.3/cli/php.ini with new version
Setting up php7.0-json (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php7.3-fpm (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/fpm/php.ini with new version
Created symlink /etc/systemd/system/multi-user.target.wants/php7.3-fpm.service → /lib/systemd/system/php7.3-fpm.service.Setting up php7.0-intl (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php-apcu (5.1.17+4.0.11-1+0~20190217111312.9+stretch~1.gbp192528) ...
Setting up php7.0-cli (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Replacing config file /etc/php/7.0/cli/php.ini with new version
Setting up php-redis (4.3.0-1+0~20190606080331.12+stretch~1.gbp0171a6) ...
Setting up php7.0-fpm (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
[ OK ] DietPi-Software | G_AGI php7.3-fpm php7.3-apcu php7.3-curl php7.3-gd php7.3-mbstring php7.3-xml php7.3-zip php7.3-mysql php7.3-redis
[ OK ] DietPi-Services | stop : php7.3-fpm
[ SUB2 ] DietPi-Software > Optimise and configure software
[ INFO ] DietPi-Software | Applying DietPi optimizations and configurations for RPi 3 Model B (armv7l), please wait...
[ SUB2 ] DietPi-Software > Configuring PHP: Hypertext Preprocessor for dynamic web content
[ OK ] DietPi-Software | Added setting upload_tmp_dir=/var/tmp/php_upload_tmp to end of file /etc/php/7.3/mods-available/dietpi.ini
PHP Warning: PHP Startup: Unable to load dynamic library 'redis.so' (tried: /usr/lib/php/20180731/redis.so (/usr/lib/php/20180731/redis.so: undefined symbol: igbinary_serialize), /usr/lib/php/20180731/redis.so.so (/usr/lib/php/20180731/redis.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
[ OK ] DietPi-Software | Added setting upload_max_filesize=2047M to end of file /etc/php/7.3/mods-available/dietpi.ini[ OK ] DietPi-Software | Added setting post_max_size=2047M to end of file /etc/php/7.3/mods-available/dietpi.ini
[ OK ] DietPi-Software | Added setting default_charset="UTF-8" to end of file /etc/php/7.3/mods-available/dietpi.ini
[ OK ] DietPi-Software | Added setting opcache.enable=1 to end of file /etc/php/7.3/mods-available/dietpi.ini
[ OK ] DietPi-Software | Added setting opcache.memory_consumption=22 to end of file /etc/php/7.3/mods-available/dietpi.ini
[ OK ] DietPi-Software | Added setting opcache.revalidate_freq=60 to end of file /etc/php/7.3/mods-available/dietpi.ini
[ OK ] DietPi-Software | Added setting apc.shm_size=22M to end of file /etc/php/7.3/mods-available/dietpi.ini
[ OK ] DietPi-Software | Added setting apc.ttl=259200 to end of file /etc/php/7.3/mods-available/dietpi.ini
[ INFO ] DietPi-Software | G_THREAD_START_0 | wget https://raw.githubusercontent.com/rlerdorf/opcache-status/master/opcache.php -O /var/www/opcache.php
[ INFO ] DietPi-Software | G_THREAD_START_1 | wget https://github.com/krakjoe/apcu/raw/master/apc.php -O /var/www/apc.php
[ INFO ] DietPi-Software | G_THREAD_WAIT_0 | wget https://raw.githubusercontent.com/rlerdorf/opcache-status/master/opcache.php -O /var/www/opcache.php
[ OK ] DietPi-Software | G_THREAD: All threads finished
[ SUB2 ] DietPi-Software > Configuring VNC4 Server: desktop for remote connection
[ SUB3 ] DietPi-Services > dietpi_controlled
[ OK ] DietPi-Services | dietpi_controlled : avahi-daemon
[ OK ] DietPi-Services | dietpi_controlled : nmbd
[ OK ] DietPi-Services | dietpi_controlled : smbd
[ OK ] DietPi-Services | dietpi_controlled : redis-server
[ OK ] DietPi-Services | dietpi_controlled : mariadb
[ OK ] DietPi-Services | dietpi_controlled : php7.0-fpm
[ OK ] DietPi-Services | dietpi_controlled : php7.3-fpm
[ OK ] DietPi-Services | dietpi_controlled : lighttpd
[ OK ] DietPi-Services | dietpi_controlled : cups
[ OK ] DietPi-Services | dietpi_controlled : cloudprintd
[ OK ] DietPi-Services | dietpi_controlled : noip2
[ OK ] DietPi-Services | dietpi_controlled : webmin
[ OK ] DietPi-Services | dietpi_controlled : cron
[ SUB3 ] DietPi-Set_hardware > headless (disable)
[ OK ] DietPi-Set_hardware | Comment in /DietPi/config.txt converted to setting: #hdmi_ignore_hotplug=0
[ OK ] DietPi-Set_hardware | Comment in /DietPi/config.txt converted to setting: #hdmi_ignore_composite=0
[ OK ] DietPi-Set_hardware | Comment in /DietPi/config.txt converted to setting: #hdmi_blanking=0
[ OK ] headless disable | Completed
[ SUB2 ] DietPi-Software > Installation completed
[ INFO ] DietPi-Patchfile | Not installed, ignoring: php5-*
[ INFO ] DietPi-Patchfile | Install verified: php7.0-*
[ INFO ] DietPi-Patchfile | Not installed, ignoring: php7.1-*
[ INFO ] DietPi-Patchfile | Not installed, ignoring: libapache2-mod-php5
[ INFO ] DietPi-Patchfile | Not installed, ignoring: libapache2-mod-php7.0
[ INFO ] DietPi-Patchfile | Not installed, ignoring: libapache2-mod-php7.1
[ INFO ] DietPi-Patchfile | APT removal for: php7.0-* , please wait...
(Reading database ... 70176 files and directories currently installed.)
Removing php-mcrypt (1:7.0+49) ...
(Reading database ... 70173 files and directories currently installed.)
Preparing to unpack .../php-fpm_2%3a7.3+69+0~20190303094804.15+stretch~1.gbp0f7465_all.deb ...
Unpacking php-fpm (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) over (1:7.0+49) ...
Preparing to unpack .../php-igbinary_3.0.1+2.0.8-1+0~20190503122633.10+stretch~1.gbp63e2f2_armhf.deb ...
WARNING: Module igbinary ini file doesn't exist under /etc/php/7.3/mods-available
Unpacking php-igbinary (3.0.1+2.0.8-1+0~20190503122633.10+stretch~1.gbp63e2f2) over (2.0.1-1) ...
(Reading database ... 70209 files and directories currently installed.)
Removing php7.0-fpm (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Removing php7.0-cli (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
(Reading database ... 70182 files and directories currently installed.)
Preparing to unpack .../php-zip_2%3a7.3+69+0~20190303094804.15+stretch~1.gbp0f7465_all.deb ...
Unpacking php-zip (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) over (1:7.0+49) ...
Removing php7.0-zip (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Preparing to unpack .../php-xml_2%3a7.3+69+0~20190303094804.15+stretch~1.gbp0f7465_all.deb ...
Unpacking php-xml (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) over (1:7.0+49) ...
Removing php7.0-xml (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
dpkg: php7.0-common: dependency problems, but removing anyway as you requested:
php7.0-intl depends on php7.0-common (= 7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff).
php7.0-json depends on php7.0-common (= 7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff).
php7.0-curl depends on php7.0-common (= 7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff).
php7.0-mcrypt depends on php7.0-common (= 7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff).
php7.0-gd depends on php7.0-common (= 7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff).
php7.0-mbstring depends on php7.0-common (= 7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff).
php7.0-opcache depends on php7.0-common (= 7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff).
php7.0-readline depends on php7.0-common (= 7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff).
php7.0-mysql depends on php7.0-common (= 7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff).
Removing php7.0-common (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
(Reading database ... 70096 files and directories currently installed.)
Preparing to unpack .../php-curl_2%3a7.3+69+0~20190303094804.15+stretch~1.gbp0f7465_all.deb ...
Unpacking php-curl (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) over (1:7.0+49) ...
Removing php7.0-curl (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
(Reading database ... 70087 files and directories currently installed.)
Preparing to unpack .../php-gd_2%3a7.3+69+0~20190303094804.15+stretch~1.gbp0f7465_all.deb ...
Unpacking php-gd (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) over (1:7.0+49) ...
Removing php7.0-gd (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Selecting previously unselected package php7.3-intl.
(Reading database ... 70078 files and directories currently installed.)
Preparing to unpack .../php7.3-intl_7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7_armhf.deb ...
Unpacking php7.3-intl (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Preparing to unpack .../php-intl_2%3a7.3+69+0~20190303094804.15+stretch~1.gbp0f7465_all.deb ...
Unpacking php-intl (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) over (1:7.0+49) ...
Removing php7.0-intl (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Removing php7.0-json (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
(Reading database ... 70069 files and directories currently installed.)
Preparing to unpack .../php-mbstring_2%3a7.3+69+0~20190303094804.15+stretch~1.gbp0f7465_all.deb ...
Unpacking php-mbstring (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) over (1:7.0+49) ...
Removing php7.0-mbstring (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Removing php7.0-mcrypt (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
(Reading database ... 70051 files and directories currently installed.)
Preparing to unpack .../php-mysql_2%3a7.3+69+0~20190303094804.15+stretch~1.gbp0f7465_all.deb ...
Unpacking php-mysql (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) over (1:7.0+49) ...
Removing php7.0-mysql (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Removing php7.0-opcache (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Removing php7.0-readline (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Setting up php-igbinary (3.0.1+2.0.8-1+0~20190503122633.10+stretch~1.gbp63e2f2) ...
Setting up php-curl (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) ...
Setting up php-zip (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) ...
Setting up php-xml (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) ...
Setting up php-mbstring (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) ...
Setting up php-fpm (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) ...
Setting up php-gd (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) ...
Processing triggers for php7.3-fpm (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Setting up php7.3-intl (7.3.6-1+0~20190531112735.39+stretch~1.gbp6131b7) ...
Creating config file /etc/php/7.3/mods-available/intl.ini with new version
Setting up php-mysql (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) ...
Setting up php-intl (2:7.3+69+0~20190303094804.15+stretch~1.gbp0f7465) ...
(Reading database ... 70020 files and directories currently installed.)
Purging configuration files for php7.0-mysql (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-readline (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-opcache (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-mbstring (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-gd (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-mcrypt (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-curl (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-cli (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
dpkg: warning: while removing php7.0-cli, directory '/etc/php/7.0/cli/conf.d' not empty so not removed
Purging configuration files for php7.0-fpm (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
dpkg: warning: while removing php7.0-fpm, directory '/etc/php/7.0/fpm/conf.d' not empty so not removed
Purging configuration files for php7.0-zip (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-json (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-common (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-xml (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
Purging configuration files for php7.0-intl (7.0.33-8+0~20190531121058.14+stretch~1.gbpe7d4ff) ...
[ OK ] DietPi-Patchfile | G_AGP php5-* php7.0-* php7.1-* libapache2-mod-php5 libapache2-mod-php7.0 libapache2-mod-php7.1
[ INFO ] DietPi-Patchfile | Not installed, ignoring: php7.2-*
[ INFO ] DietPi-Patchfile | Not installed, ignoring: libapache2-mod-php7.2
[ INFO ] DietPi-Patchfile | None of the requested packages are currently installed. Aborting...
[ OK ] DietPi-Patchfile | G_AGP php7.2-* libapache2-mod-php7.2
[ INFO ] DietPi-Patchfile | APT installation for: php7.3-intl, please wait...
[ OK ] DietPi-Patchfile | G_AGI php7.3-intl
[ INFO ] DietPi-Update | Patching 6.23.1 to 6.24
[ OK ] DietPi-Update | Patching to v6.24.1 completed
