6.22.3 upd on NUC Topic is solved
Re: 6.22.3 upd on NUC
That is great. Thanks for testing and reporting back. I will also run some test here and check the update path and merge this branch into master then.
Indeed that was an important find!
Okay tests went smooth, checked again what might be different when doing reboot first but there is nothing included in the reboot that would affect update success. The other way round it is: The incremental patches are required for older version before reboot succeeds as intended.
Merged into master: https://github.com/MichaIng/DietPi/pull/2684
I hope with this even the last issues, still from v6.20 update system changes, are fixed.
Regardless of this fix I will now update the x86 BIOS image. Needs testing as well as prior images were created by Fourdee with a different x86 system. Even that those should work on all x86 systems some tests/verifications would be great, just to be failsafe.
