journalctl -u raspotify.service
It reports:Joulinar wrote: ↑Sun May 03, 2020 9:23 pm you could have a look to journalctl
-- Logs begin at Sun 2020-05-03 19:30:24 BST, end at Sun 2020-05-03 21:44:24 BST. --
May 03 19:30:24 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Unit entered failed state.
May 03 19:30:24 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Failed with result 'signal'.
May 03 19:30:34 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Service hold-off time over, scheduling
May 03 19:30:34 NanoPi-NEO-Plus2 systemd[1]: Stopped Raspotify.
May 03 19:30:34 NanoPi-NEO-Plus2 systemd[1]: Starting Raspotify...
May 03 19:30:34 NanoPi-NEO-Plus2 systemd[1]: Started Raspotify.
May 03 19:30:34 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Main process exited, code=killed, statu
May 03 19:30:34 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Unit entered failed state.
May 03 19:30:34 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Failed with result 'signal'.
May 03 19:30:44 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Service hold-off time over, scheduling
May 03 19:30:44 NanoPi-NEO-Plus2 systemd[1]: Stopped Raspotify.
May 03 19:30:44 NanoPi-NEO-Plus2 systemd[1]: Starting Raspotify...
May 03 19:30:44 NanoPi-NEO-Plus2 systemd[1]: Started Raspotify.
May 03 19:30:44 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Main process exited, code=killed, statu
May 03 19:30:44 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Unit entered failed state.
May 03 19:30:44 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Failed with result 'signal'.
May 03 19:30:55 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Service hold-off time over, scheduling
May 03 19:30:55 NanoPi-NEO-Plus2 systemd[1]: Stopped Raspotify.
May 03 19:30:55 NanoPi-NEO-Plus2 systemd[1]: Starting Raspotify...
May 03 19:30:55 NanoPi-NEO-Plus2 systemd[1]: Started Raspotify.
May 03 19:30:55 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Main process exited, code=killed, statu
May 03 19:30:55 NanoPi-NEO-Plus2 systemd[1]: raspotify.service: Unit entered failed state.
/usr/bin/librespot --name NanoPi-NEO-Plus2
No... i\t reports ''illegal instruction''.Joulinar wrote: ↑Mon May 04, 2020 2:47 am hmm unfortunately no real error message. Maybe you can try to run raspotify executable manually.
does it give anything?Code: Select all
Yes that's the definitely the problem here as my OS is the Ubuntu Xenial img compiled by Friendly Elec.
I got all RPis! I previously used a RPi Zero on that streamer I had built.
