Wifi Hotspot Topic is solved
Re: Wifi Hotspot
Yes, but only after a backup restore, this problem keeps showing up again and again!
Re: Wifi Hotspot
@cocoflan
Which RPi model do you use?
And which WiFi adapter (if not an internal one): lsusb
In case it is an external USB WiFi dongle, please try the following:
the next depends on RPi and WiFi adapter model
cd /tmp
wget https://dietpi.com/downloads/binaries/all/hostapd_2.5_all.zip
unzip hostapd_2.5_all.zip
rm hostapd_2.5_all.zip
Re: Wifi Hotspot
It is a RPI 3 B+ that i use.
Re: Wifi Hotspot
So the internal WiFi I bet... hmm then I have no idea why it fails currently, the steps I started are then not applicable.
A debug start then:
A debug start then:
systemctl status hostapd
systemctl stop hostapd
hostapd /etc/hostapd/hostapd.conf
Re: Wifi Hotspot
● hostapd.service
Loaded: masked (/dev/null; bad)
Active: inactive (dead)
RPI 3 B+
solution ???
● hostapd.service
RPI 3 B+
solution ???
Re: Wifi Hotspot
i have left my device off yesterday, and tested the steps again today, it is working again.
So don't know what is the real problem, thx for the info.
