Gmrender does not release audio interface Topic is solved
vords
Re: Gmrender does not release audio interface
Post by vords »
well, there is actualy a lot of logs . What should i look for ?
Should i "| grep" something or can i "tail -f" the command and check in real time ?
journalctl -u gmrender -f would be tail the log constantly until you cancel it
vords
Post by vords »
Thanks Joulinar :)
Here is the end of the logs, i've played 8 sec of a track
mai 03 10:12:24 DietPi gmediarender[30467]: INFO  [2021-05-03 10:12:24.172597 | transport] RelativeTimePosition: 0:00:06
mai 03 10:12:25 DietPi gmediarender[30467]: INFO  [2021-05-03 10:12:25.173724 | transport] RelativeTimePosition: 0:00:07
mai 03 10:12:26 DietPi gmediarender[30467]: INFO  [2021-05-03 10:12:26.174805 | transport] RelativeTimePosition: 0:00:08
mai 03 10:12:27 DietPi gmediarender[30467]: INFO  [2021-05-03 10:12:27.174412 | transport] TransportState: STOPPED
mai 03 10:12:27 DietPi gmediarender[30467]: INFO  [2021-05-03 10:12:27.174495 | transport] CurrentTransportActions: PLAY,SEEK
mai 03 10:12:27 DietPi gmediarender[30467]: INFO  [2021-05-03 10:12:27.174674 | transport] LastChange: <?xml version="1.0"?>
mai 03 10:12:27 DietPi gmediarender[30467]: <Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/">
mai 03 10:12:27 DietPi gmediarender[30467]: <InstanceID val="0">
mai 03 10:12:27 DietPi gmediarender[30467]: <TransportState val="STOPPED"></TransportState>
mai 03 10:12:27 DietPi gmediarender[30467]: <CurrentTransportActions val="PLAY,SEEK"></CurrentTransportActions>
mai 03 10:12:27 DietPi gmediarender[30467]: </InstanceID>
mai 03 10:12:27 DietPi gmediarender[30467]: </Event>
It seems to be "STOPPED".
So i guess the app is sending the correct information ?
yap looks like an Event was sent with a value STOPPED.
vords
Post by vords »
After reading this post :
https://www.audiosciencereview.com/foru ... 03/page-69
It could be an usb power issue.
I'm going to try and test differents configurations and see.
But it's maybe not a Dietpi issue or question, so i won't bother you more with this :)
Thanks you both for your help !
I wouldn't wonder indeed. USB power is a typical issue on SBCs, although I'd have expected the Sparky SBC to be prepared well for USB DACs in this regards :?.
While it may not be a DietPi issue, it would be great to know if you found a solution, so probably we can add it to our docs, e.g. our GMediaRender docs, of as part of a general troubleshooting part when it comes to blocked audio devices :).
vords
Post by vords »
Sure, i will let you know if i find a solution.
