[Solved] Color depth issue with Chromium Kiosk
locutusweb
Re: [Solved] Color depth issue with Chromium Kiosk
Post by locutusweb »
@MichaIng
I added the following option:
Option          "alpha_swap" "true"
to /etc/X11/xorg.conf but this made no difference.
If I can help (send a log?) please let me know.
@locutusweb
And you did the apt commands as well, purging the obsolete mali driver and reinstalling the other ones?
Please try to use all commands exactly as I posted (including overwriting the xorg.conf with cat. Indeed the alpha_swap should be the only difference, but to be failsafe if anything is using the Identifier case sensitive (FBTURBO <> FBTurbo), so we can be 100% rule out any differences from our install method compared to the "setup-odroid" tool ones.
I also opened an issue on GitHub: https://github.com/MichaIng/DietPi/issues/2943
locutusweb
Yes, I did purge the stuff. Thanks.
