[Solved] Need Help Installing Driver Topic is solved
sledwards
Re: Need Help Installing Driver
Post by sledwards »
@MichaIng
There was no pre-req files listed in my driver package. I found this link which I thought would be the solution:
https://www.pcsuggest.com/install-rtl8153-driver-linux/
Went thru all the steps, and at when I tried my USB 3.0 to Gigabit dongle, it did not work. Unfortunately, the ethernet port was also disabled and I had no way back into the machine via ssh (no monitor or keyboard). So I started over with a fresh install of dietpi. My gut feeling is this would be plug and play if dietpi for Sparky used a newer kernel (4.x).
Anyways, I did do a dmesg after insmod and got a very generic warning message within. I will need to repeat the whole procedure again to give you a better answer. Maybe if you take a look at the link I provided it will shed some light as to whats going on.
Steve
sledwards
Post by sledwards »
@MichaIng
Following that new procedure again with fresh install of dietpi, I get this:
root@Office:/Downloads# sudo apt-get install libelf-dev build-essential linux-headers-`uname -r`
Reading package lists... Done
Building dependency tree
E: Unable to locate package linux-headers-3.10.38
E: Couldn't find any package by glob 'linux-headers-3.10.38'
E: Couldn't find any package by regex 'linux-headers-3.10.38'
I am guessing I really need those linux-headers for my install? Any suggestions?
The Linux headers for Sparky SBC are not available on APT repo. Check my first answer again about the steps to download and place the headers manually.
A newer kernel would be great, but the official upstream kernel is still on v3.10.38: https://github.com/sparkysbc/Linux
Also ARMbian does not have an image for it. They usually have updated own build kernels, but Sparky SBC is not in their portfolio.
sledwards
Post by sledwards »
@MichaIng
Here is the dmesg error after insmod:
r8152: Unknown symbol _GLOBAL_OFFSET_TABLE_ (err 0)
Again little web search attempt:
Can you edit the Makefile in the drivers directory, find the line starting with MODFLAGS or CFLAGS_MODULE and append -fno-pic (with leading white space)?
Then rerun make and retry to enable the module.
sledwards
Post by sledwards »
@MichaIng
I can not find those commands. Here is the entire Makefile:
ifneq ($(KERNELRELEASE),)
obj-m := r8152.o
# EXTRA_CFLAGS += -DRTL8152_S5_WOL
# EXTRA_CFLAGS += -DRTL8152_DEBUG
else
KERNELDIR ?= /lib/modules/$(shell uname -r)/build
PWD :=$(shell pwd)
TARGET_PATH := kernel/drivers/net/usb
INBOXDRIVER := $(shell find $(subst build,$(TARGET_PATH),$(KERNELDIR)) -name r8152.ko.* -type f)
RULEFILE = 50-usb-realtek-net.rules
RULEDIR = /etc/udev/rules.d/
.PHONY: modules
modules:
$(MAKE) -C $(KERNELDIR) SUBDIRS=$(PWD) modules
.PHONY: all
all: clean modules install
.PHONY: clean
clean:
$(MAKE) -C $(KERNELDIR) SUBDIRS=$(PWD) clean
.PHONY: install
install:
ifneq ($(shell lsmod | grep r8152),)
rmmod r8152
endif
ifneq ($(INBOXDRIVER),)
rm -f $(INBOXDRIVER)
endif
$(MAKE) -C $(KERNELDIR) SUBDIRS=$(PWD) INSTALL_MOD_DIR=$(TARGET_PATH) modules_install
modprobe r8152
.PHONY: install_rules
install_rules:
install --group=root --owner=root --mode=0644 $(RULEFILE) $(RULEDIR)
endif
Okay then add the line: CFLAGS_MODULE = -fno-pic directly after the three # at the top.
sledwards
Post by sledwards »
@MichaIng
Well, new errors:
After insmod:
ERROR: could not insert module r8152.ko: Device or resource busy
dmesg reads:
Error: Driver 'r8152' is already registered, aborting...
If I do an 'lsmod', I do not see the driver
Module Size Used by
nls_cp437 5150 1
ethernet 64021 0
spidev 6636 0
atc260x_cap_gauge 27668 0
atc260x_irkeypad 12310 0
autofs4 29844 0
sledwards
Re: [Solved] Need Help Installing Driver
Post by sledwards »
@MichaIng
Thanks for all of the help. I am purchasing a new adapter that has been reported to work with the Sparky USBridge.
