I simply don't understand. It is working to me but now for me it is more important to understand why it is working and why following what wg0-client.conf suggests instead does not make it working.
Did you have time to do some test?
I re-attached my wg0-client.conf:
[Interface]
# The address must be unique for each client, use "10.8.0.3/24" for the second client and so on.
Address = 10.8.0.2/24
PrivateKey = HIDDEN
# Comment the following to preserve the clients default DNS server, or force a desired one.
DNS = 192.168.1.1
# Kill switch: Uncomment the following, if the client should stop any network traffic, when disconnected from the VPN server
# NB: This requires "iptables" to be installed, thus will most likely not work on mobile phones.
#PostUp = iptables -I OUTPUT ! -o %i -m mark ! --mark -m addrtype ! --dst-type LOCAL -j REJECT && ip6tables -I OUTPUT ! -o %i -m mark ! --mark -m addrtype ! --d$
#PreDown = iptables -D OUTPUT ! -o %i -m mark ! --mark -m addrtype ! --dst-type LOCAL -j REJECT && ip6tables -D OUTPUT ! -o %i -m mark ! --mark -m addrtype ! --$
[Peer]
PublicKey = HIDDEN
# Tunnel all network traffic through the VPN:
# AllowedIPs = 0.0.0.0/0, ::/0
# Tunnel access to server-side local network only:
# AllowedIPs = 192.168.1.0/24
# Tunnel access to VPN server only:
# AllowedIPs = 192.168.1.2/32
AllowedIPs = 192.168.1.0/32
Endpoint = HIDDEN
# Uncomment the following, if you're behind a NAT and want the connection to be kept alive.
#PersistentKeepalive = 25
