ntp systemd-timesyncd issue
IamxHM
Re: ntp systemd-timesyncd issue
Post by IamxHM »
No I don't remember installing ntp. I will just remove ntp. Thanks both of you for your time and help.
WarHawk
Post by WarHawk »
IamxHM wrote: Thu Nov 29, 2018 4:15 pm I happened to see this, which says ntp service may be is conflicting with the timesyncd. So I commented few condition lines in timesyncd config and it worked. The website further says to purge the ntp. Should I do that?
BOOM! Worked like a champ!
I purged ntp
Thanks!
