Pi-hole interfering with website (port 80?) Topic is solved
Fourdee
Re: Pi-hole interfering with website (port 80?)
Post by Fourdee »
artic wrote:
ErrorLog /error.log
        #CustomLog ${APACHE_LOG_DIR}/access.log combined
RewriteEngine on
RewriteCond %{SERVER_NAME} =myserver.duckdns.org
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
</VirtualHost>
Strange, DocumentRoot /var/www/nextcloud is missing. Is this the full contents of the file?
artic
Post by artic »
yep it is, I've never touched anything about this folder, nevermind, I'm going to make a fresh install of the whole system soon :D
