REQ: NextCloud
Deleted User 612
Re: REQ: NextCloud
Post by Deleted User 612 »
Hi Fourdee,
That is odd, a foolish assumption by me. I installed it on a Raspbaerry Pi 3.
I'll test it on a clean install and post the outcome.
Edit: It was specifically only the /.user.ini file that failed.
Deleted User 612
Re: REQ: NextCloud
I retried it and it worked fine. When I previously tried it, I had to go through the web installer for some reason. My thinking is that this happened because I had changed all the root Mysql passwords from the default "dietpi", so NextCloud couldn't install via the command line, I had forgot that I received an error about this, which I ignored :roll:
I might be alone in wanting to change my passwords from the default but do you think there would be anyway of allowing the user to choose there own admin name user and password? Or if there's anyway to change it post-install, I just personally don't feel it's secure enough for me to have that as the admin login.
Sorry for being so difficult, the automated install is really awesome, the reason I'm not manually installing is because of all the other good stuff you've added in, I just wish there was a way to change a few parameters. :D
GitHub Issue here https://github.com/Fourdee/DietPi/issues/533
artic
Re: REQ: NextCloud
Post by artic »
srry for the OT but is there any tutorial on how to setup nextcloud with letsencrypt? :D ty
Fourdee
Re: REQ: NextCloud
Post by Fourdee »
artic wrote:srry for the OT but is there any tutorial on how to setup nextcloud with letsencrypt? :D ty
First, you'll need a domain name eg: mywebsite.com that points to your device.
More info: http://dietpi.com/phpbb/viewtopic.php?f ... 1061#p1062
If you are using Apache2 or Lighttpd webserver, you can install letsencrypt with:
dietpi-software install 92
Then configure it with:
/DietPi/dietpi/dietpi-letsencrypt
artic
Re: REQ: NextCloud
Post by artic »
"You're a legend" quote ;D
Fourdee
Re: REQ: NextCloud
Post by Fourdee »
artic wrote:"You're a legend" quote ;D
lol :)
