AdGuard Home - network-wide ad-and-tracker blocking DNS server with Parental control
Re: AdGuard Home - network-wide ad-and-tracker blocking DNS server with Parental control
Adguard Home does not work if you only enter the ip without the port number
What you do you mean by this? Which port you need to specify? Usually this should not be needed to configure DNS on your clients/router
twilightened
Post by twilightened »
Joulinar wrote: Tue Apr 28, 2020 11:18 am
In this screen during the set up, i had to enter different port numbers than the ones written. It said that those ports were taken. So i guess that is why i had to enter ip addresses with port numbers. I uninstalled pihole before installing adguard home, so i have no idea why these ports were taken. I am not really a network specialist to be honest.
listen interfaces can be set to all interfaces. No need to change anything there. Attached a screen shot from my test system.
Next to that port 53 on DNS server is fine, this is the standard port and know by all Router. So entering the DNS Server IP on your router is sufficient. No need to enter a port in addition on your router.
twilightened
Joulinar wrote: Tue Apr 28, 2020 4:07 pm listen interfaces can be set to all interfaces. No need to change anything there. Attached a screen shot from my test system.
In this screen, Adguard Home told me that those ports were taken and i have to change them with a red font text. I couldn't click next without changing the ports. And when i change the port numbers, ip addresses have an extension with the new port number. Just entering the ip address did not work, i tried it.
Can you do a screen print from these red messages? Do you have another web server and DNS server running already? Otherwise ports shouldn't be blocked
twilightened
Thanks for the time you are taking for this. I will try to install it again tonight. I will take the screenshot and put it here. When i first installed it, i made sure that pihole was uninstalled before. I thought that they might clash. And i don't have any web server or anything. Just one wireless modem/router. DHCP is provided by the modem.
yes pihole will bring a webserver as well. so you need to ensure non of them is installed. better to start with an empty installation. ;)
twilightened
Joulinar wrote: Tue Apr 28, 2020 11:55 pm yes pihole will bring a webserver as well. so you need to ensure non of them is installed. better to start with an empty installation. ;)
aha, that could be the problem. I only uninstalled pihole. I didn't know about the webserver. Maybe the webserver was still running then. Let me try again, this time i will try to uninstall the webserver as well.
can be done by using dietpi-software. If not needed you can remove these software title. But depends on your use case and if you need some of them
[ ] 81   LLSP: lighttpd | sqlite  | php
[ ] 84   Lighttpd: webserver
[ ] 87   SQLite: database
[ ] 89   PHP: Hypertext Preprocessor for dynamic web content
[ ] 93   Pi-hole: block adverts for any device on your network
twilightened
Joulinar wrote: Wed Apr 29, 2020 12:11 am can be done by using dietpi-software. If not needed you can remove these software title. But depends on your use case and if you need some of them
Dude, thanks for the help man. It worked :) I will probably make a clean reinstall of dietpi sometime in the future to clean up the residual files, but Adguard Home is currently working and blocking. It also starts automatically after a reboot.
