Nanopi M-4
Re: Nanopi M-4
I will setup a qemu-chroot environment soon and try to create a testing image by this. I should be able to do this until end of the week, have to see how much adjustment to DietPi-PREP is required to allow it running inside a chroot environment.
Re: Nanopi M-4
Just installed nanopi on second microsd card, with the NANOPCT4 installation script on my NANOPI M4.
Used Armbian 5.91 buster image and the installerscript
Now i gone test if all works.
I keep you informed.
Re: Nanopi M-4
Wifi network is in the air, but i get an error when enabling the hotspot:
Can connect but no internet.
No working leases in persistent database - sleeping.
iptables-restore v1.8.2 (nf_tables):
line 3: CHAIN_UPDATE failed (No such file or directory): chain PREROUTING
line 4: CHAIN_UPDATE failed (No such file or directory): chain INPUT
line 5: CHAIN_UPDATE failed (No such file or directory): chain POSTROUTING
line 6: CHAIN_UPDATE failed (No such file or directory): chain OUTPUT
ifup: failed to bring up wlan0
Any idea someone?
For the rest the system works better than before with the NANOPI T4 image script, only the sound and wifi keeps me busy. No solution yet found for the sound, or it is with an external usb dongle. Wifi there a think.
Greeting
Any idea someone?
Greeting
