[Solved] Ethernet issues on Odroid C1 after updating
Edward
Re: Ethernet issues on Odroid C1 after updating
Post by Edward »
I can confirm that I have issues on my Asus Tinker Board as well....its hit and miss, mostly miss with Ethernet connection on boot.
Just for kicks I installed another OS [volumio] boots and connects with no problem every time.
Could you please try it with the current beta
https://github.com/Fourdee/DietPi/issues/2140
https://github.com/Fourdee/DietPi/blob/ ... _SYSTEM.md
And do you have a WiFi adapter attached as well? Could you try to disable it via dietpi-config in case?
€: Ah as mentioned above already. Or did you mean after update to beta?
Edward
Post by Edward »
I would like to try the dev branch for the Odroid C2 except it won't connect to the network.
Did a fresh install, everything worked up until the last step where I installed the Dietpi system, upon reboot I lost my network connection. No way to ssh into the Odroid C2.
Edward
Post by Edward »
Found the problem.....at least for me.
The Ethernet was not broken....it IP address changed !!
I looked on my router and saw a new IP address, I ssh'd into it and behold.....it was the Odroid C2.
Next I tried connecting to wifi using a dongle.....worked fine.
Rebooted and wifi connected no problem
Rebooted again just for kicks and it worked without a hitch.
8)
Please try it with the just today released v6.17 update. Of course it should again automatically apply on 1st boot.
If it still does not work, please open an issue on GitHub, so we can investigate/debug it there more closely: https://github.com/Fourdee/DietPi/issues
Edward
Post by Edward »
Odroid issues on my C2 seem to be solved...everything working perfectly.
Once again thank you Dietpi Team for all your hard work on this!
That's great, thanks for your feedback! :)
