Adr3nal1n wrote: ↑Thu Oct 04, 2018 11:13 pmNot sure how to check this.
Easy. Use
to monitor what's happening in another shell while running benchmarks (benchmarking without monitoring is pretty useless):
wget https://raw.githubusercontent.com/ThomasKaiser/sbc-bench/master/sbc-bench.sh
chmod 755 sbc-bench.sh
sudo ./sbc-bench.sh -m
Since you're using a Rock64 you can also check whether DietPi deleted rock64_diagnostics.sh since if not you have my code already and can run
Results will then look like this (for more examples check links in right column here
https://github.com/ThomasKaiser/sbc-ben ... Results.md):
Time CPU load %cpu %sys %usr %nice %io %irq Temp
05:38:47: 1392MHz 3.19 26% 7% 17% 0% 1% 0% 45.5°C
05:39:17: 1392MHz 3.14 78% 1% 76% 0% 0% 0% 56.8°C
05:39:48: 1392MHz 3.19 84% 1% 82% 0% 0% 0% 58.6°C
05:40:19: 1392MHz 3.38 85% 1% 83% 0% 0% 0% 61.7°C
This is a Rock64 with recent Armbian image (there I added the 1.4GHz cpufreq OPP but we did not allow for the 1.5 GHz settings since too many instability reports occured). With ayufan images you can dynamically load a DT overlay for the higher clockspeeds and since DietPi is just a modified userland on top of ayufan's work it should work here exactly the same (for details do a web search for 'ayufan DT overclock' or something like that)
SSDs with trashed performance is quite common when powered by SBC, the reason is usually undervoltage and not undercurrent (on almost all SBC USB ports there are current limiters in action exceeding the commonly known 500mA for USB2 or 900mA for USB3 -- ROCK64 allows 650mA on each USB2 port and 950 mA on the USB3 port but a RPi 3 uses 1.2A for all 4 USB2 ports combined or a NanoPi M4 for example has one global 2A current limiter for all 4 USB3 ports -- you always need to study schematics).
But as already said: usually it's undervoltage (cable/contact resistance between PSU and board and again between board and disk) causing the problems and not limited current (same on the RPi 3 where 1.2A are set by default -- compare with 'vcgencmd get_config int' output -- but due to Polyfuses and Micro USB powering the voltage available to USB peripherals often drops below 4.5V and then majority of external SSDs get in trouble, the majority of 2.5" HDD already has trouble with less than 4.75V)
