Locked
Fourdee
Post by Fourdee »
ownCloud Details:
Your very own personal cloud based backup/data storage system (eg: Dropbox) with ownCloud.
- Also Installs: Webserver
- USB dedicated hard drive highly recommended.
Access web interface:
url = http://localhost/owncloud where 'localhost' can be substituted by local server IP or hostname, to access remotely.
username = admin
password = dietpi
You may want to configure your ownCloud from command line via occ command: ownCloud admin manual
We added a shortcut to the otherwise necessary 'sudo -u www-data php /var/www/owncloud/occ':
Just use 'occ' followed by the desired command inside your terminal.
FAQ:
Where is my data stored?
  • /mnt/dietpi_userdata/owncloud
Why am I limited to 2GB file size uploads?
DietPi will automatically apply the max supported upload size to the PHP and Nextcloud configs.
  • 32bit systems can handle 2GB
  • 64bit systems can handle 8796PB, yep, in petabyte
  • echo -e "$(( $(php -r 'print(PHP_INT_MAX);') / 1024 / 1024))MB"
Will my data be saved after uninstallation?
  • Your userdata directory will stay after uninstallation.
  • As well a database backup will be saved to your userdata directory.
  • Thus you can easily restore your instance by reinstalling ownCloud and restore the database dump.
Fourdee
Post by Fourdee »
RPi Cam Control:
Got a RPi camera module?
Want to record paint drying using timelapse, or, start your own neighbourhood watch surveillance system? Want full control of your RPi camera in a web based interface. This is all you need!
NB: Documentation updated and applies to DietPi v6.3+
Requires:
- Official RPi camera module (any)
url = http://192.168.0.100/rpicam
Where is the recoded media stored?
- /mnt/dietpi_userdata/rpicam
Fourdee
Post by Fourdee »
ReadyMedia / MiniDLNA
Stream your shared media to any DLNA/UPnP capable device.
DLNA T.jpg (72.26 KiB) Viewed 601593 times
Access ReadyMedia status:
url = http://192.168.0.100:8200
Transfer Media files to ReadyMedia:
- Make sure you have one of DietPi's File Servers installed.
- Folders used by ReadyMedia = /Music /Pictures /Video
To refresh the ReadyMedia database:
rm /mnt/dietpi_userdata/.MiniDLNA_Cache/* && systemctl restart minidlna
List of available UPnP clients:
https://en.wikipedia.org/wiki/List_of_U ... AV_clients
Fourdee
Post by Fourdee »
YMPD:
A lightweight, bare-bones, no frills Hifi music player with a web based interface. YMPD is a front end for MPD.
Also installs:
  • MPD (music player daemon)
url = http://192.168.0.100:1337
Transfer/Add Music: Refresh Music Files / Database:
Simply select the Update DB button. from the settings menu in YMPD.
DietPi-JustBoom control panel: Tweak audio options on the fly
Simply run dietpi-justboom from the command line to launch
Fourdee
Post by Fourdee »
Forum (phpbb3) Details:
If you always wanted your very own forum, PHPBB3 is all you need.
Access Forums:
url = http://192.168.0.100/phpBB3
First Run Setup:
DietPi automatically creates the SQL database for phpBB3. Please follow the steps below to enter those details into phpBB3 to complete the setup.
- Access the phpBB3 website = http://192.168.0.100/phpBB3
- Click the "Install" tab.
- Click "Proceed to next step"
- Click "Start install"
Enter the MySQL database details:
- Database server hostname or DSN = localhost
- Database username = phpbb3 (Previous to DietPi v6.0 = root)
- Database name = phpbb3
- Database password = dietpi
Create your admin account:
This account will be used for full access to phpBB3 forum.
Email and Server URL settings
Use the default values.
The database tables will now be generated, please wait.
Login:
- Click "Login"
Using your admin login details that you created previously, you can now manage and create your forum pages.
As the installation is now completed, you will need to remove the installation folder, before the forum can be live. Run the following command:
rm -R /var/www/phpBB3/install
Your forum is now ready.
Fourdee
Post by Fourdee »
Apache2 Webserver Stacks:
Host your own websites with:
  • LAMP Webserver = Linux, Apache2, MariaDB, PHP
  • LASP Webserver = Linux, Apache2, SQlite, PHP
All stacks come with PHP caches (APCU and OPcache). The sizes of which are optimized based on a share of total memory.
DietPi-Software | Webserver Preference System:
DietPi will install webserver stacks automatically, when required, based on your preference. Click here to find out more.
Access website:
local directory = /var/www
Access phpinfo:
url = http://192.168.0.100/phpinfo.php
Access memcache info:
APC/u = http://192.168.0.100/apc.php
Opcache = http://192.168.0.100/opcache.php
MySql / MariaDB Details:
username = root
password = dietpi
Optional - Enable SSL (https):
Lets Encrypt is highly recommended.
This will automate the creation and setup of your free SSL cert. It couldn't be simpler.
Optional - Alternative Enable SSL (https):
Create key:
mkdir -p /etc/apache2/ssl
openssl req -x509 -nodes -days 1000 -newkey rsa:2048 -keyout /etc/apache2/ssl/apache.key -out /etc/apache2/ssl/apache.crt
Enable SSL config and restart Apache:
chmod 600 /etc/apache2/ssl/*
cat << _EOF_ > /etc/apache2/sites-enabled/default-ssl.conf
<IfModule mod_ssl.c>
        <VirtualHost _default_:443>
                ServerAdmin [email protected]
                ServerName example.com:443
                DocumentRoot /var/www
                LogLevel error
                ErrorLog ${APACHE_LOG_DIR}/error.log
                #CustomLog ${APACHE_LOG_DIR}/access.log combined
                SSLEngine on
                SSLCertificateFile /etc/apache2/ssl/apache.crt
                SSLCertificateKeyFile /etc/apache2/ssl/apache.key
                <FilesMatch "\.(cgi|shtml|phtml|php)$">
                                SSLOptions +StdEnvVars
                </FilesMatch>
                <Directory /usr/lib/cgi-bin>
                </Directory>
                BrowserMatch "MSIE [2-6]" \
                                nokeepalive ssl-unclean-shutdown \
                                downgrade-1.0 force-response-1.0
                BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
        </VirtualHost>
</IfModule>
_EOF_
a2enmod ssl
service apache2 restart
You can now access your webserver securely with https://192.168.0.100
Fourdee
Post by Fourdee »
Nginx Webserver Stacks:
  • LEMP Webserver = Linux, Nginx, MariaDB, PHP
  • LESP Webserver = Linux, Nginx, SQlite, PHP
All stacks come with PHP-FPM and PHP caches (APCU and OPcache). The sizes of which are optimized based on a share of total memory.
Access phpinfo:
username = root
password = dietpi
Fourdee
Post by Fourdee »
phpMyAdmin Details:
Web interface SQL admin tool for webserver installations.
Access phpmyadmin:
url = http://192.168.0.100/phpmyadmin
- username = phpmyadmin (Previous to DietPi v6.0 = root)
- password = The same as your root login password. Default is dietpi
Fourdee
Post by Fourdee »
ProFTP - FTP Server Details:
Access files/music/downloads etc. on your DietPi system quickly and efficiently with minimal overheads.
Accessing ProFTP with Windows:
- Goto My Computer (Windows Explorer).
- In the address bar at the top type ftp://root:[email protected] press enter.
NB: Change 192.168.0.100 to the IP address of your DietPi system.
Accessing ProFTP with a FTP Client:
username = dietpi (v6.2 and lower = root)
address = Your ip address (eg: 192.168.0.100)
port = 21
How do I change the destination directory?
- Replace /Path/To/Directory to your target directory.
systemctl stop proftpd
sed -i '/DefaultRoot /c\DefaultRoot /Path/To/Directory' /etc/proftpd/proftpd.conf
systemctl start proftpd
How do i enabling "jailing" (lock users to their home folders)?
sed -i "/DefaultRoot /c\DefaultRoot ~" /etc/proftpd/proftpd.conf
systemctl restart proftpd
Fourdee
Post by Fourdee »
Samba - File Server Details:
Share files on your DietPi system with ease.
Accessing Samba File Server
- Address = \\192.168.0.100\dietpi or \\dietpi\dietpi
- username = dietpi (DietPi v6.12 and lower = root)
- password = dietpi
Optional: Change Samba password:
smbpasswd -a dietpi
Optional add/change the valid user:
  • Edit /etc/samba/smb.conf
  • Under the entry [dietpi], change valid users = username_i_require
  • Add the user to Samba with smbpasswd -a username_i_require
  • Restart services with dietpi-services restart
  • You can now connect to the samba server with the username and password you entered above.
Optional: How do I change the destination directory?
sed -i '/path = /c\path = /Path/To/Directory' /etc/samba/smb.conf
Locked
