Locked
Fourdee
v151
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/media/#koel
Koel
Web interface music streamer.
Access web interface:
  • URL = http://192.168.0.100:8000
  • Email address = The one you entered during installation
  • Password = The one you entered during installation
First Run Setup:
Configure Koel to use the DietPi user data (music) directory:
  • In the web interface, on the left hand side click settings
  • Under Media Path, enter /mnt/dietpi_userdata/Music
  • Then click Scan
Transfer/Add Music:
Fourdee
v152
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/bittorrent/#sonarr
Sonarr
Automatically download your favorite TV shows, as they become available.
NB: A download client is required:
- Transmission BitTorrent server is recommended to enable automatic downloads.
Access web interface: First Run Setup:
Before you can add TV shows, you'll need to select a search indexer to use from the web interface:
  • Simply goto Settings > Indexer then choose at least one indexer.
Setup your download client:
  • Simply goto Settings > Download Client, select your installed download client and enter required credentials.
Setup file creation mask:
  • If you require write access from other applications (e.g. Plex subtitle downloads), you'll also need to set the file/folder creation mask to allow this.
    • In the Sonarr web interface, select Settings
    • Toggle to Advanced settings slider (enable it)
    • Under Media Management tab, scroll down to the bottom of the page under Permissions, set the following values:
    • Save changes
Add a TV show:
  • Simply select Series > Add TV Show
  • Type a name of the show you wish to find
  • Once found, under path use the following location /mnt/dietpi_userdata/downloads
  • Change any further options (such as video quality) if needed, then select +
Using custom download/media directories outside of /mnt/:
Since DietPi v6.29, by default Sonarr has strict permissions to only access download and media directories inside /mnt/. If you need to use a different location, please do the following:
  • 1. Run dietpi-services from console
  • 2. Select sonarr
  • 3. Select Edit
  • 4. Uncomment (remove leading #) the line, starting with ReadWritePaths=
  • 5. Add your custom path to the end of this line, separated by one space
  • 6. Press ctrl+o buttons to save and ctrl+x to exit
Link databases to RAM:
Link the Sonarr info/settings database to RAM to increase access performance, reduce disk I/O and avoide constant external HDD spinning due to the very regular access to these files: viewtopic.php?f=8&t=5828
Recommended: Protect your privacy with a VPN:
Although we enable forced encryption on all our BitTorrent clients, if you wish to ensure complete privacy and peice of mind for all your downloaded content, using a VPN is critical.
Fourdee
v152
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/bittorrent/#radarr
Radarr
Automatically download your favorite movies, as they become available.
Before you can add movies, you'll need to select a search indexer to use from the web interface:
  • Simply goto Settings > Indexers then choose at least one indexer.
    • In the the web interface, select Settings
    • Save changes
Add a Movie:
  • Simply select Add Movies
  • Type a name of the movie you wish to find
Since DietPi v6.29, by default Radarr has strict permissions to only access download and media directories inside /mnt/. If you need to use a different location, please do the following:
  • 2. Select radarr
  • 3. Select Edit
Link the Radarr info/settings database to RAM to increase access performance, reduce disk I/O and avoide constant external HDD spinning due to the very regular access to these files: viewtopic.php?f=8&t=5828
Fourdee
v152
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/media/#tautulli
Tautulli
A Python-based monitoring and tracking tool for Plex Media Server.
Access web interface: http://<your.IP/domain>:8181
Access log files: /mnt/dietpi_userdata/plexpy/logs/
Fourdee
v152
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/bittorrent/#jackett
Jackett
API Support for your favorite torrent trackers.
Jackett works as a proxy server: it translates queries from apps (Sonarr, Radarr, SickRage, CouchPotato) into tracker-site-specific http queries, parses the html response, then sends results back to the requesting software. This allows for getting recent uploads (like RSS) and performing searches.
Access web interface: Recommended: Protect your privacy with a VPN:
Fourdee
v152
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/bittorrent/#nzbget
NZBGet
Extremely efficient and fast NZB download manager with web interface. Coded in C++.
Access Web Interface: Access Downloads:
Fourdee
v154
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/printing/#octoprint
OctoPrint
OctoPrint provides a web interface for controlling consumer 3D printers.
Access Web Interface: First Run Setup:
Once connected to the web interface:
  • Simply run through the setup wizard and configure the software/printers as needed.
  • Section: Server Commands:
    • Restart OctoPrint = systemctl restart octoprint
    • Restart system = reboot
    • Shutdown system = poweroff
  • Section: Software Updates:
    • OctoPrint checkout folder = /opt/octoprint (since DietPi v6.33)
OctoPrint data/config directory: /mnt/dietpi_userdata/octoprint (since DietPi v6.33)
Command Line Interface (CLI): (relevant since DietPi v6.33)
  • Run the octoprint command as user octoprint to invoke the correct config/data directory.
  • On a regular bash session this is the case automatically via alias and sudo, see: /etc/bashrc.d/dietpi-octoprint.sh
  • If you use a different shell, use: sudo -u octoprint octoprint <command>
Fourdee
v154
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/media/#roon-server
Roon Server
Turns your device into a Roon capable audio player and core server.
Install a Roon Remote on another system:
You can use the Roon Remote apps to control and configure the Roon Server. Recommended Music Storage Directory:
When configuring your Roon Server, we highly recommend using the DietPi user data directory. This will allow you to transfer music over the network easily (see Transfer Music below), and storing the music on your Roon Server system.
  • /mnt/dietpi_userdata/Music
Transfer Music:
Fourdee
v154
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/gaming/#steam
Steam
Steam client.
Installation notes:
  • Steam is installed to the DietPi user data directory /mnt/dietpi_userdata/steam
  • By default, installing games will install them to /mnt/dietpi_userdata/steam
Fourdee
v154
Post by Fourdee »
Deprecation warning: This post is deprecated. Please find our new documentation at: https://dietpi.com/docs/software/bittor ... pc-manager
HTPC Manager
HTPC Manager combines all your favourite software into one slick interface.
Do all your HTPC tasks without using 5 different interfaces!
Access Web Interface: Update to latest version:: dietpi-software reinstall 155
Locked
