[Request] Add the PI-HOLE fonctionnality
Fourdee
Re: [Request] Add the PI-HOLE fonctionnality
Post by Fourdee »
DietPirate wrote:These reasons include the fact that PiHole's adblocking does not work 100% of the time, and another more important reason is that having a webserver running could in fact be a security liability depending on your setup. See http://www.cvedetails.com/vulnerability ... httpd.html and note that the latest lighttpd version available via apt-get from DietPi/Raspbian repo is only 1.4.31
Hi DietPirate,
Interesting research, thanks for posting.
The DietPi installation for Pi-hole will be based on the LASP stack. This stack was chosen as its used for all other webserver based software on DietPi (owncloud/forums etc). This also prevents multiple webservers being installed and conflicting.
I'am looking to release DietPi v80 (with the Pi-hole installation option) today. Will also post when its available.
mathieubzh
Post by mathieubzh »
Fourdee could you add the choise of the web server LASP LESP ....
And the index.html :
<html>
<body>
</body>
</html>
Fourdee
Post by Fourdee »
mathieubzh wrote:Fourdee could you add the choise of the web server LASP LESP ....
Not at the moment. LASP was selected as all of DietPi's installation options that require a webserver stack run on apache2. This also ensures compatibility across all the DietPi optimized installation options that may require a webserver to function (eg: Forums, Grasshopper, Owncloud etc etc).
A choice of webservers is a great idea, but the downside is the user could end up installing more than 1 webserver (eg: Apache2 + Nginx).
LEMP and LESP are there for advanced users who specifically need a Nginx stack. Those users can then manually setup the additional webbased software they require.
When DietPi-Software changes to an SQL driven database, i'll be able to look into a webserver choice system. This will be a big task, but it is planned for the distant future.
Index file generated = https://github.com/Fourdee/DietPi/blob/ ... 2003-L2008
Fourdee
Post by Fourdee »
DietPi v80 has been released. This includes the installation option for:
Pi-hole - A DNS/Web server that will block ads for any device on your network.
Simply run dietpi-update, or, write a new DietPi image
DietPirate
Post by DietPirate »
Great job, looking forward to updating!
