Cloudshell on Odroid XU4 feature request
Fourdee
Re: Cloudshell on Odroid XU4 feature request
Post by Fourdee »
johnvick wrote:Just tried this out buy using this link I found in the Github thread - I'm still on v119.
wget https://raw.githubusercontent.com/Fourd ... cloudshell -O /DietPi/dietpi/dietpi-cloudshell
This gives dietpi-cloudshell v6.
It gives a message:
Screen will be powered down in under 1 minute.
setterm: terminal xterm does not support --blank
setterm cannot (un)set powersave mode: input output error.
Maybe it relies on something else that is to be in v120?
Hi John,
I think you may also require this updated script:
wget https://raw.githubusercontent.com/Fourdee/DietPi/testing/dietpi/login -O /DietPi/dietpi/login
The new powersaving feature will only work when DietPi-Cloudshell has been launched during boot. This is because we can only change the powersaving display features on the screen we originate from. Basically means we cant turn on/off the display if the program was launched over SSH. I pretty much exhausted all available options to try and prevent this: https://github.com/Fourdee/DietPi/issue ... -225637243
Workaround:
Lets set autostart for dietpi-cloudshell, run the following command and then select dietpi-cloudshell from the list:
dietpi-autostart
Reboot system. If you start or stop DietPi-Cloudshell at any point via the control panel, it will not be able to control the display. So after you have changed and applied any settings, please ensure you reboot.
I know, not an ideal solution, but its the only method that works at the moment.
johnvick
Legend
Post by johnvick »
Hi Fourdee,
I've installed that script, set Cloudshell to autoboot (was before anyhow) and switch off in an hour (just missed 7 am) and I'll post here what the result is. In the meantime I have found another possible bug - I have a few NFS shares on a QNAP that are mounted on the XU4. The QNAP powers of at 11:30 pm. From then on the Cloudshell screen sticks with a message about shares not being available. When the QNAP comes on in the morning the Cloudshell screen starts to rotate again.
Thanks for you work on this, John
Fourdee
Post by Fourdee »
johnvick wrote:The QNAP powers of at 11:30 pm. From then on the Cloudshell screen sticks with a message about shares not being available
Hi John,
Where are the mount points for your QNAP shares? (eg: /mnt/samba).
Its also worth noting, when in powersaving mode, DietPi-Cloudshell will not update the scenes, to save wasteful processing :)
If you want to test:
You can set the hour to the current hour, save changes. Once rebooted, DietPi-Cloudshell will then match the current hour and power screen off straight away.
I have my XU4 set to 10pm off and 8am on. Really handy to have and saves us a few pence on electric :D
Let me know how you get on with your test. If theres any issues, we'll sort it :)
johnvick
Legend
Post by johnvick »
The NFS shares are for example in /mnt/Multimedia and several similar ones.
Just gone 8 am and the screen didn't go off - I have to go to work, I'll test it later today.
johnvick
Legend
Post by johnvick »
Hi Fourdee,
Working nicely thanks for adding this feature.
John
Fourdee
Post by Fourdee »
johnvick wrote:Hi Fourdee,
John
Excellent, thanks for letting me know :)
Fourdee
Post by Fourdee »
John,
I forgot to mention.
As DietPi v120 is now released, if you run dietpi-update, it will overwrite your dietpi-cloudshell start/stop times as it doesn't expect those values to exist yet.
You can either:
- Open DietPi-Cloudshell and renable the powersaving option, then set your times up again.
Or:
- copy and paste into terminal (Start powersaving at 10pm, stop at 8am):
7s = line number
/22/ = desired value (22:00 hours)
sed -i '7s/.*/1/' /DietPi/dietpi/.dietpi-cloudshell #Enabled?
sed -i '8s/.*/22/' /DietPi/dietpi/.dietpi-cloudshell #Start time (hour)
sed -i '9s/.*/8/' /DietPi/dietpi/.dietpi-cloudshell #End time (hour)
Make sure to reboot the system after doing the above, to ensure the powersaving feature can function.
johnvick
Legend
Post by johnvick »
Hi Fourdee,
One observation I have made this morning is that the Cloudshell screen still sticks on a screen with an error message if the the NFS shares are not available - still happening. Not a huge problem, the QNAP holding the shares powers down at about the same time as the Cloudshell screen and powers up again a bit after the Cloudshell screen in the morning, which is how I caught this today. Once the QNAP is fully booted the Cloudshell screen starts to rotate again.
John
Fourdee
Post by Fourdee »
John
Hi John,
I've created a Git ticket for this issue. You can track the progress here: https://github.com/Fourdee/DietPi/issues/395. I'll try and take a look tomorrow.
