Doesn't DietPi suport OrangePi any more?
darren
Re: Doesn't DietPi suport OrangePi any more?
Post by darren »
WarHawk wrote: Tue Dec 18, 2018 4:45 pm
Then using Fourdee's most awesome PREP script...it should blow out the old and install the new as long as you have internet connection and know some simple Linux commands
#wget https://github.com/Fourdee/DietPi/blob/master/PREP_SYSTEM_FOR_DIETPI.sh
#chmod 755 PREP_SYSTEM_FOR_DIETPI.sh
# ./PREP_SYSTEM_FOR_DIETPI.sh
Hi, sorry for digging this up in 2021, but the wget link you supplied retrieves the html page from GitHub, not the script. The correct command should be:
wget https://raw.githubusercontent.com/MichaIng/DietPi/master/PREP_SYSTEM_FOR_DIETPI.sh
usage of DietPi PREP script is describe on our online docs https://dietpi.com/docs/hardware/#make- ... stribution
Thanks for the hint, I updated the post as well, a typical mistake I do myself by times :).
