hostname change = no boot
pictsidhe
Re: hostname change = no boot
Post by pictsidhe »
I've been setting up a headless pi4 for datalogging with a piplate this evening.
First attempt, I edited dietpi.txt to do a bunch of stuff and it failed to boot. One of those things was changing the hostname. I just burned a fresh image and started again, but without a lot of the stuff in dietpi.txt.
I had a lot of fun getting piplates to play. it needs python2 to run...
polishing things up after doing that, I get to changing the hostname, this time in dietpi-config.
I can no longer find it with nmap or log in to the ip it usually has.
I pull the card and put it in my laptop. etc/hosts and etc/hostname have both been changed to my new hostname. dietpi.txt has not. i change hosts and hostname back to DietPi.
Still no login :(
I'm not looking forward to redoing the piplates installation.
I did all this on a pi zero a few days ago only to discover it wasn't fast enough. The hostname change i put in dietpi.txt worked just fine, though. Something is different with the arm64 version?
Any tips on tracking this down? I have ramlog...
the hostname change done on dietpi.txt is applicable on first initial boot only. The value is marked with AUTO_SETUP
##### DietPi-Automation settings, applied on first boot of DietPi only, ONCE! #####
# Hostname
AUTO_SETUP_NET_HOSTNAME=DietPi
Means it is fully correct that this was not changed while using dietpi-config
It might be best to connect a screen if your system did not boot after you have done some changes. This way we could see what happen. I doubt changing the hostname will breake your system.
pictsidhe
Post by pictsidhe »
I've tried it two ways now. Both ways broke the system
1st was changing dietpi.txt before first boot. I also changed a bunch of other stuff so it could have been something else that broke that one. Though it was stuff that worked fine on a pi zero...
2nd attempt I left dietpi.txt mostly alone and used the dietpi-config utility after setting up everything else. That left DietPi as the hostname in dietpi.txt and changed it in etc/hosts and etc/hostname. I tried changing it back, but still no ssh on boot :/ the green led flickers for a while when starting up, then goes off, leaving the red one on. What else does it change other than etc/hosts and etc/hostname?
I don't have a way to hook up a screen to a pi4
I need this running for Monday, so looks like I need to do another clean install. :/
Part of getting the piplate to install was purging python3. Related?
Curiouser and curiouser, said Alice.
I think I changed ramlog to ramlog + 1 hour save while setting up, so thought it would be worth plugging it in and leaving it. Damn thing came up this time, with no changes since last attempt! Seems a good time to take an image of the card before trying anything else...
Without screen it will be quite hard to find out what the issue of the system is.
Are you sure python 2 is needed? Because on the PiPlate docs they describe the installation for python 3 as follow
For Python3, type: sudo pip3 install pi-plates and hit <ENTER>
pictsidhe
Post by pictsidhe »
The logging software throws a bunch of syntax errors when tried with python3. I'm no python coder, so don't want to try fixing them all.
well you should report it to PiPlate developer if there are error using Python3. This way they probably have the chance to fix it.
