Hi bbmak,
bbmak wrote:one more question,
please have a look:
root@oDroid-C1-TEST:~# cat /etc/network/interfaces
#/etc/network/interfaces
#Please use DietPi-Config to modify network settings.
# Local
auto lo
iface lo inet loopback
# Ethernet
allow-hotplug eth1
will say, if you want to alter your network settings, please use menu "
7 Network Options: Adapters " in:
root@oDroid-C1-TEST:~# dietpi-config
- DietPi-Config - Network Settings
In this menu you can as well disable WiFi adapter:
- DietPi-Config - WiFi Adapter
bbmak wrote:do I need to comment the #dns-nameservers 8.8.8.8 8.8.4.4 If I do not want the wifi?
Correct is:
# Wifi
bbmak wrote: In your quote, you did put a comment there.
dietpi-config " did this. Where is no need, to edit "
/etc/network/interfaces " manually, to disable WiFi adapter.
But if you edit the file manually before, you have to set it now "once" by hand, so dietpi-config can work correct.
BWT: - to have one, both, fallback network adapters working at the same time, having two different gateways or subnets, working infrastructure mod, static IP or dhcp, with WiFi HotSpot, with PiHole installed and so on, is a new feature in v116/ v117:
https://github.com/Fourdee/DietPi/issue ... -210905921
And yes, it was a long and stony journey for @Fourdee to get it on work.
