I successfully updated to v79. Dual IP case seems to be no more, but the original problem of having no Internet access is still there. Only thing left is to try a fresh image flashing and that will take some self-convincing.
Thanks for everything, Fourdee.
No internet when on WiFi when on static IP Topic is solved
Re: No internet when on WiFi when on static IP
Hi,o/\o wrote:but the original problem of having no Internet access is still there. Only thing left is to try a fresh image flashing and that will take some self-convincing.
I ran a test today on my RPI with static wifi ip, was unable to replicate the issue. I've checked through your network settings.
The only thing i can see might be wrong is your gateway:
gateway 192.168.100.53
Unless you have specified this in your router lan settings, this should be 192.168.*.1.
I would recommend you try the following to copy the working IP addresses from DHCP:
- Run dietpi-config 8
- goto the Wifi Menu
- change from STATIC to DHCP and select "Apply Save Changes (Restart Networking)"
- Now your setup with the working DHCP ip address, you can use "Copy Copy Current address to Static", then change to STATIC and save again "Apply Save Changes (Restart Networking)".
Hi, Dan. No, that's proper, it's not an error.Fourdee wrote:Hi,o/\o wrote:but the original problem of having no Internet access is still there. Only thing left is to try a fresh image flashing and that will take some self-convincing.
I'll give it a go. Just to rectify my previous post, dual IPs are still here ater the v79 update. It's not a problem, it's not giving me any issues, only something I wanted to mention.Fourdee wrote:I would recommend you try the following to copy the working IP addresses from DHCP:
I'll try and find the time over the w-end to do a fresh install of DietPi and cross my finger that'll solve the issues.
