Using UART
Re: Using UART
@jhorv
Sorry for missing reply.
Instead of making the tty world-writeable, please add the nodered user to the tty group: usermod -aG tty nodered
Instead of only disabling Bluetooth, might might be required to switch Bluetooth serial device usage by adding dtoverlay=miniuart-bt to /DietPi/config.txt. AFAIK otherwise ttyAMA0 does not listen to the GPIO ports.
EDIT: Ah nope, disable-bt should be sufficient to allow ttyAMA0 listening to GPIO ports.
jhorv
Re: Using UART
Post by jhorv »
Many thanks for the hint, better late than never. :D
I had been thinking of adding chmod a+rw /dev/ttyS0 to the /etc/rc.local file but that's absolutely not secure and your suggestion is obviously the best way to do it.
Meanwhile, after I updated DietPi from v6.25.3 to v6.26.3 I have been able to now access ttyAMA0 through node-red and python. Bluetooth is still disabled but since I don't use it (yet) that's not much of a concern for the time being.
Thanks again!
