[Tutorial] How to get your NanoHatOLED to work
Re: [Tutorial] How to get your NanoHatOLED to work
The install.sh expects rc.local to be present and enabled. Please try this before running install.sh:
>> /etc/rc.local
grep 'exit 0' /etc/rc.local ||  sed -i -e '$aexit 0' /etc/rc.local
chmod +x /etc/rc.local
Oh, and the script adds the OLED start command not very failsafe...:
2020-03-29 19:31:28 root@micha:/tmp# cat test
exit 0
2020-03-29 19:31:31 root@micha:/tmp# sed -i -e '$i \/usr/local/bin/oled-start\n' test
2020-03-29 19:31:40 root@micha:/tmp# cat test
exit 0
If there is a newline after the exit 0, it is never executed...
So please verify that /usr/local/bin/oled-start is present before exit 0:
cat /etc/rc.local
Also since the source code has not been updated the last 3 years the question is if it's still compatible with newest Python, i.e. Python3?
buesche
Post by buesche »
why not use a systemd service?
[Unit]
Description=NanoHAT OLED
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/usr/local/bin/oled-start
[Install]
WantedBy=multi-user.target
and oled-start:
#!/bin/sh
cd /root/NanoHatOLED
./NanoHatOLED
The OLED screens does work with python3 (at least on my nanopi neo air with dietpi on it).
FrogPI
Post by FrogPI »
Greetings !
Yet another bash at getting this OLED to work. Things "seem" to be moving forward, hopefully.
Being new to Linux (30 years of Windoze and 10 of Apples) code seems quite daunting at first, but thanks to the Interweb, it looks as if I am getting somewhere.
I couldn't get my head around MichaIng's post and couldn't figure it out, but then from "buesche" post I chased info on the systemd service thingy, and found some information on the Raspberry website I quote :
"NOTE: on Jessie, Stretch and Buster (which use systemd), rc.local has drawbacks: not all programs will run reliably, because not all services may be available when rc.local runs.
See systemd for another way to have a command or program run when Raspberry Pi boots."
Obviously this is a learning curve for me, so this is what I did, please correct if I am doing things wrong (I'm all ears from the pros) :
From a fresh eMMC flash (DietPi_NanoPiNEO2Black-ARMv8-Buster.img)
copy NanoHatOLED.tar.gz to /home folder via cp (from another machine onto the eMMC)
ssh into dietpi
run dietpi-config
install 130 + 16 + 17
root@DietPi:~# python --version
Python 2.7.16
root@DietPi:~# cd /etc
root@DietPi:~# ls
# an rc.local file is present
root@DietPi:~# cd /home
root@DietPi:~# cd NanoHatOLED
root@DietPi:~# run ./install.sh
Python 2.7.16
#still same Python version 2.7.16 and has not been updated via install.sh
root@DietPi:~# sudo nano oled.service
# copy buesche's code to oled.service
# [Unit]
# Description=NanoHAT OLED
#[Service]
#Type=oneshot
#RemainAfterExit=yes
#ExecStart=/usr/local/bin/oled-start
#[Install]
#WantedBy=multi-user.target
root@DietPi:~# sudo cp oled.service /etc/systemd/system/oled.service
root@DietPi:~# sudo reboot
# after reboot
root@DietPi:~# sudo systemctl start oled.service
root@DietPi:~# sudo systemctl status oled.service
● oled.service - NanoHAT OLED
Loaded: loaded (/etc/systemd/system/oled.service; disabled; vendor preset: en
abled)
Active: active (exited) since Mon 2020-03-30 11:11:34 BST; 15s ago
Process: 982 ExecStart=/usr/local/bin/oled-start (code=exited, status=0/SUCCES
S)
Main PID: 982 (code=exited, status=0/SUCCESS)
Tasks: 5 (limit: 1023)
Memory: 17.9M
CGroup: /system.slice/oled.service
├─985 ./NanoHatOLED
├─988 sh -c cd /home/NanoHatOLED/BakeBit/Software/Python && python3 b
akebit_nanohat_oled.py 2>&1 | tee /tmp/nanoled-python.log
├─991 python3 bakebit_nanohat_oled.py
└─992 tee /tmp/nanoled-python.log
Mar 30 11:11:34 DietPi systemd[1]: Starting NanoHAT OLED...
Mar 30 11:11:34 DietPi systemd[1]: Started NanoHAT OLED.
# The service seems to be starting without any problems, and HTOP shows a NanoHatOLED service runnning, but still no OLED , Grrrr !
Any ideas would be greatly appreciated, in NOOB language if possible ;.)
Yeah a systemd unit is the obvious solution on systemd-driven systems indeed. It is not what the original install.sh does, so just take care to not double things.
rc.local on modern Debian/DietPi is btw as well started via systemd unit ;): systemctl status rc-local
But it requires the rc.local file to be executable, which is not the case by default.
Okay, so we have the script started now but it does not lead to any OLED output :(.
Does i2cdetect btw show expected output, so that I2C is really enabled?
FrogPI
Post by FrogPI »
Hi MichaIng
thanks for your prompt reply.
Sorry for my ignorance, but how can I check that systemd & rc.local are not being doubled up, as you say ?
Here is the output of :
red stuff is obviously not good news :.(
An i2c detect shows :
Screen Shot 2020-03-30 at 17.48.59.png (13.41 KiB) Viewed 2489 times
I'll be very honest, I am a tad out of my league here, and any help is greatly appreciated, cheers.
FrogPI
Post by FrogPI »
PS : No OLED output whatsoever, not a blink !
Aldoszx
Post by Aldoszx »
It is working for me, but slightly modified in order to put the startup script on /var/lib/dietpi/postboot.d/
Install instructions:
1. Enable i2c (add to armbianEnv.txt): overlays=i2c0 usbhost1 usbhost2
2. Make sure the following components have been installed using the DietPi Software configuration tool
<Software Additional> => 16 Build Essentials
<Software Additional> => 17 Git
3. Download attached NanoHatOLED.tar.gz and copy archive to installation folder (e.g. /home)
cd /home
tar -pxvzf NanoHatOLED.tar.gz
cd NanoHatOLED
./install.sh
That is all !
Now it should work.
Later edit:
the script installs Python 3.7, python-pip, etc
Later later edit:
I forgot to mention, I am using maarten's package for Python 3 !
Thanks maarten !
I've also modified the installer in order to use systemd, based on oled.script proposed by buesche.
I am using it on Armbian and it is working fine !
NanoHatOLED.tar.gz
(410.42 KiB) Downloaded 186 times
maarten
Post by maarten »
@ dornt, FrogPI
try following and re-install NanoHatOLED:
MichaIng commented on 25 Feb
@maartenlangeveld
Many thanks for testing. Could you please try to edit /boot/armbianEnv.txt and add:
i2c0 to the overlays line, so it should look like this:
overlays=usbhost1 usbhost2 i2c0
There is also an i2c1 overlay available, not sure which one uses which pins.
And if you don't use Docker, add the following as new line as well, which should lead to minor performance enhancements:
docker_optimizations=off
Fatguy5150
Post by Fatguy5150 »
Hi everybody. Thanks for the great posts. I got a new NanoPi Neo2 Black and have been struggling to make the OLED work. Aldoszx your instructions/script work perfectly and I get to run dietpi like I want!
I was also able to get this to work using Ubuntu; showing the pi-hole stats and updating the shutdown screen to the pi-hole disable for 15mins option, but can’t seem to get them to work here on dietpi.
https://www.reddit.com/r/pihole/comment ... e_machine/
https://imgur.com/a/1BLo01B
I’ve mostly been trying to modify the bakebit_nanohat_oled.py file but to no avail. Any ideas on how to access the pi-hole stats/disable options?
Hardware: NanoPi Neo2 Black
OS: DietPi_NanoPiNEOBlack-ARMv8-Buster (beta)
Thanks again for the awesome posts, it's really cool to get this thing working.
