[Tutorial] How to get your NanoHatOLED to work
Re: [Tutorial] How to get your NanoHatOLED to work
@maarten
Jep those are update persistent.
maarten
Post by maarten »
great! Thanks Micha !
scheiner
Post by scheiner »
I had to recompile the kernel and then installed DietPi over it. Now it shows "Linux DietPi 4.19.25-sunxi64 #5.76 SMP" under uname.
I can't make NanoHatOLED work.
When I try "systemctl enable rc-local.service" I get this message :
dietpi@DietPi:~$ sudo systemctl enable rc-local.service
The unit files have no installation config (WantedBy, RequiredBy, Also, Alias
settings in the [Install] section, and DefaultInstance for template units).
This means they are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
1) A unit may be statically enabled by being symlinked from another unit's
.wants/ or .requires/ directory.
2) A unit's purpose may be to act as a helper for some other unit which has
a requirement dependency on it.
3) A unit may be started when needed via activation (socket, path, timer,
D-Bus, udev, scripted systemctl call, ...).
4) In case of template units, the unit is meant to be enabled with some
instance name specified.
Any ideas?
Thanks
rc-local system has changed in Debian, conflicting some old DietPi leftover. Please check for solution: https://github.com/MichaIng/DietPi/issues/2566
scheiner
Post by scheiner »
Thanks for the info Micha.
Not working. Did the install, than rebooted..
But even trying to run manually it's not working.
But ... the ./NanoHatOLED is showing under htop however nothing shows at the display.
maarten
Post by maarten »
Same here, worked like a charm up until recently. Now it is not working anymore. Black screen.
However htop shows the deamon is runnning...
scheiner
Post by scheiner »
i2c not working here ...
sudo i2cdetect -y 0
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
how can I enable it ?
maarten
Post by maarten »
After several reboots it seems to work again. However, NanoHatOLED display starts working not immediately after (re)boot but it takes a delay...
scheiner
Post by scheiner »
it's finally working fine.
Phillski
Post by Phillski »
Just updated from 6.19.7 to 6.24.1 and everything is working for me, I'm assuming the more recent versions of DietPi have a workaround in place for whatever gremlins were affecting people.
