[Testers Wanted] Simple PIA VPN Gateway
ifndefx
Re: [Testers Wanted] Simple PIA VPN Gateway
Post by ifndefx »
Hi, just a quick question will can this purely be used as a VPN Client. I only want my pi to use the vpn.
G33RT
Post by G33RT »
Yes a VPN Client so you can setup other computers gateway to point to the Pi IP address.
Regards, G33RT
G33RT
Post by G33RT »
Does not work, need to update if you ask me.
Regards, G33RT
VPNPortals
Post by VPNPortals »
Open Settings and tap on Wireless Controls.
Tap on VPN Settings.
Tap on Add VPN.
In the VPN Name field, enter Private Internet Access.
For Type, Choose L2TP/IPSec PSK.
In Server address Enter us-california.privateinternetaccess.com.
Leave L2TP Secret and IPSec Identifier blank.
In the IPSec Pre-shared key type: mysafety
Tap Save
Tap on Private Internet Access
Enter your Generated Username and Password If you have not generated this yet, please follow the steps here
Check Save account information if you want to save the password
Tap Connect
coachhahn
Post by coachhahn »
When I get to the install where it asks to select an endpoint nothing comes up in the list.
Phillski
Post by Phillski »
odd, I just tried it with a fresh DietPi install and I got the full list.
Could you try running the script again, it's possible it failed to download the endpoints from the PIA website.
coachhahn
Post by coachhahn »
Phillski wrote: Wed Feb 19, 2020 4:30 am odd, I just tried it with a fresh DietPi install and I got the full list.
I can't because it cut off internet access to the vm
Phillski
Post by Phillski »
I'm fairly certain it won't have been caused by this script as the only things it will have done up until that point were to install the openvpn client and download a zip file from PIA, all the killswitch functionality is configured last and it does not touch any networking configuration.
Galvinized83
Post by Galvinized83 »
I've been using this since Aug 2019 & (while the setup didn't go smoothly for me) now it's up & running, it's worked flawlessly ever since.
Thank you for this script - it's a great help
ainuke
Post by ainuke »
+1000 likes for this!
SUPER easy setup script for me.
I did run into an issue with enabling the kill switch. The install seemed to hang there, and maybe I just wasn't patient enough, but I exited the install and re-ran it, opting to not enable the kill switch.
Do agree with the previous post that specifies additions for DNS leaking. The two lines they specified adding worked for me.
FWIW.
Now I'm on to attempt opening an incoming port for Deluge. If you have a magical way to do this, I'd be psyched!
Erik
Official Pi4 4GB
LoveRPi POE HAT, ArgonOne Fan HAT, WD SSD over USB3
SAB, Sonarr, Radarr, Lidarr, Deluge, PIA-VPN
Official Pi4 4GB - attempting Mine OS
"The mistakes you learn from don't have to be your own."
