[Testers Wanted] Simple PIA VPN Gateway
PDXUser
Re: [Testers Wanted] Simple PIA VPN Gateway
Post by PDXUser »
Thank you for doing this. :)
It seems to work good and match what the IP should be.
As for use? Mostly to keep prying eyes out of what I do on the web so they can't sell my data to third parties (a.k.a. ISP).
db10
Post by db10 »
martymoose wrote: Sat May 26, 2018 11:06 pm is there any chance of incorporating nordvpn. or others?
cheers good work
Same! I've Been breaking myself for two days to get PureVPN working as a client... As for me, I'd like a 24-7 RPi2 Torrentbox, running OpenVPN, Deluge, Sonarr & Radarr. Would love to test this.
WarHawk
Post by WarHawk »
Nice!!!!
luzifia
Post by luzifia »
Ty for that.
I've had some days ago some problems with vpn and a special function.
have a look at that may you integrate in your solution the "port open function" for transmission and other program.
i have market the TCP Packs with a VPN User so that all communication from this user goes through the tunnel and the rest eg. PLEX and others can come out directly.
viewtopic.php?f=11&t=5701
@MichaIng
I will see if I can implement mine for testing into DietPi-NordVPN.
have a nice day
Neilj1983
Post by Neilj1983 »
Hi,. Just installed on a fresh dietpi on a pi2. Worked fine,except I had to install pihole as a DNS server. Otherwise I had no DNS responses. I assume I did something wrong...but I have no idea what...
@Neilj1983
Hmm which upstream DNS server uses Pi-hole then? The same should work for your system as well.
If you use DHCP for your network connection, then your router serves the DNS entry for the system. That should usually work, however in your case obviously not. If you choose static IP, you can set the DNS entry yourself. Usually using the router itself works best, as most serve as DNS resolver themselves and have a DNS cache as well, but if not, then 8.8.8.8 (Google DNS) is a reliable solution, at least to test general system-wise DNS resolving.
time wget --spider https://dietpi.com can be used to test and compare speeds.
Galvinized83
Post by Galvinized83 »
I tried this last night & sadly (out of the box) from a fresh install it didn’t work. I did get it working though 👍.
With a fresh install the device it was installed on was working & getting its public IP from PIA, it just wasn’t able to route any traffic over the VPN.
I just made sure “sysctl -p” was run on startup & everything is working fine now. This I don’t think is a problem with this script as it does the same when setting up PiVPN/OpenVPN.
hknoisyboy
Post by hknoisyboy »
db10 wrote: Mon Aug 06, 2018 5:06 pm
cheers good work
I suggest configuring it on the remote machine to accept ThinClient connections. In this manner, we can use the actual Deluge desktop client on another computer (be it a windows, Linux, or OS X box) to control the Raspberry Pi Deluge installation. You get all the benefits of the desktop client on your actual desktop, while the all the action happens on the remote box.
G33RT
Post by G33RT »
This does not work for me.
Installed on a Pine64.
Also I set a static IP 192.168.1.5 before installing the script, after a reboot it reports at startup a IP 192.168.1.144 although I have a SSH session via 192.168.1.5 :?
DietPi IP address.JPG (25.59 KiB) Viewed 4616 times
Regards, G33RT
G33RT
Post by G33RT »
After I Enable IPv6 in the dietpi-config and re-run the script again it now reports the IP address 192.168.1.5 correctly.
So I guess when you Disable the IPv6 the script does not work correctly !?
DietPi IP address OKAY.JPG (29.8 KiB) Viewed 4611 times
Regards, G33RT
