journalctl -u apache2
-- Logs begin at Thu 2018-03-08 08:35:07 CET, end at Wed 2018-03-14 19:35:57 CET. --
mar 08 08:35:43 Rpi-Srv systemd[1]: Starting The Apache HTTP Server...
mar 08 08:35:44 Rpi-Srv apachectl[945]: [Thu Mar 08 08:35:44.784857 2018] [core:error] [pid 956]
(EAI 2)Name or service not known: AH00547: Could not resolve host name *:80="" -- ignoring!
mar 08 08:35:45 Rpi-Srv systemd[1]: Started The Apache HTTP Server.
journalctl -t mysqld
-- Logs begin at Thu 2018-03-08 08:35:07 CET, end at Wed 2018-03-14 19:39:20 CET. --
mar 08 08:35:49 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:49 3069299920 [Note] /usr/sbin/mys
qld (mysqld 10.1.23-MariaDB-9+deb9u1) starting as process 1184 ...
mar 08 08:35:50 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:50 3069299920 [Note] InnoDB: Using
mutexes to ref count buffer pool pages
mar 08 08:35:50 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:50 3069299920 [Note] InnoDB: The I
nnoDB memory heap is disabled
mar 08 08:35:50 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:50 3069299920 [Note] InnoDB: Mutex
es and rw_locks use GCC atomic builtins
mar 08 08:35:50 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:50 3069299920 [Note] InnoDB: GCC b
uiltin __atomic_thread_fence() is used for memory barrier
mar 08 08:35:50 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:50 3069299920 [Note] InnoDB: Compr
essed tables use zlib 1.2.8
Linux native AIO
generic crc32 instructions
mar 08 08:35:50 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:50 3069299920 [Note] InnoDB: Initi
alizing buffer pool, size = 128.0M
mar 08 08:35:50 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:50 3069299920 [Note] InnoDB: Compl
eted initialization of buffer pool
mar 08 08:35:50 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:50 3069299920 [Note] InnoDB: Highe
st supported file format is Barracuda.
mar 08 08:35:51 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:51 3069299920 [Note] InnoDB: 128 r
ollback segment(s) are active.
mar 08 08:35:51 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:51 3069299920 [Note] InnoDB: Waiti
ng for purge to start
mar 08 08:35:51 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:51 3069299920 [Note] InnoDB: Perc
ona XtraDB (
http://www.percona.com) 5.6.35-80.0 started; log sequence number 10239770
mar 08 08:35:51 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:51 2529162048 [Note] InnoDB: Dumpi
ng buffer pool(s) not yet started
mar 08 08:35:51 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:51 3069299920 [Note] Plugin 'FEEDB
ACK' is disabled.
mar 08 08:35:51 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:51 3069299920 [Note] Server socket
created on IP: '127.0.0.1'.
mar 08 08:35:52 Rpi-Srv mysqld[1185]: 2018-03-08 8:35:52 3069299920 [Note] /usr/sbin/mys
qld: ready for connections.
mar 08 08:35:52 Rpi-Srv mysqld[1185]: Version: '10.1.23-MariaDB-9+deb9u1' socket: '/var/
run/mysqld/mysqld.sock' port: 3306 Raspbian 9.0
these are the logs of the states, all the applications of the system are installed with dietpi-software and practically configured in the same way, can not be due to lack of CPU?
