V6.2 -- DietPi-Sync Behaving Differently?
midnightwatcher
Re: V6.2 -- DietPi-Sync Behaving Differently?
Post by midnightwatcher »
Hi gentlemen, I updated to version 6.3 and did a dry run of DietPi-Sync. When it completed it had asked if I wanted to view the log, however when I clicked OK was unable to see any details. I'm using JuiceSSH on my Nexus 6P phone.
Fourdee
Post by Fourdee »
midnightwatcher wrote:Hi gentlemen, I updated to version 6.3 and did a dry run of DietPi-Sync. When it completed it had asked if I wanted to view the log, however when I clicked OK was unable to see any details. I'm using JuiceSSH on my Nexus 6P phone.
Thanks for the report.
Confirmed, we'll get this resolved for v6.4, which will be released as a hotfix tomorrow.
midnightwatcher
Hi Fourdee, I see that 6.4 is now available and attempted to update, however now I am receiving an error stating that "Available free space on RootFS is low (0 MB)" and that I need to free up at least 500 MB of space. I'm surprised by this since the Z83 has a 32GB eMMC.
Any idea what could have happened??
Fourdee
Post by Fourdee »
midnightwatcher wrote:Hi Fourdee, I see that 6.4 is now available and attempted to update, however now I am receiving an error stating that "Available free space on RootFS is low (0 MB)" and that I need to free up at least 500 MB of space. I'm surprised by this since the Z83 has a 32GB eMMC.
Strange, whats the results of?:
df -h
G_TREESIZE /
midnightwatcher
root@DietPi:~# df -h
udev            957M     0  957M   0% /dev
tmpfs           194M  8.7M  185M   5% /run
/dev/mmcblk0p2   28G   28G   16K 100% /
tmpfs           968M     0  968M   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           968M     0  968M   0% /sys/fs/cgroup
tmpfs           967M  8.0K  967M   1% /tmp
tmpfs            20M   32K   20M   1% /var/log
tmpfs            10M  1.5M  8.6M  15% /DietPi
tmpfs           194M   12K  194M   1% /run/user/0
/dev/sda2       7.3T  5.0T  2.0T  72% /media/root/Media_Server
root@DietPi:~# G_TREESIZE /
du: cannot access '/proc/2958/task/2958/fd/4': No such file or directorydu: cannot access '/proc/2958/task/2958/fdinfo/4': No such file or directory
du: cannot access '/proc/2958/fd/3': No such file or directory
du: cannot access '/proc/2958/fdinfo/3': No such file or directory
5.0 TB /
4.9 TB /media
26.1 GB /root
1.2 GB /usr
271.2 MB /lib
240.9 MB /var
36.1 MB /boot
8.7 MB /sbin
8.7 MB /run
8.6 MB /bin
5.3 MB /etc
1.4 MB /DietPi
52.0 KB /mnt
16.0 KB /lost+found
16.0 KB /home
12.0 KB /srv
8.0 KB /tmp
4.0 KB /opt
4.0 KB /lib64
0.0 KB /sys
0.0 KB /proc
0.0 KB /dev
Last edited by midnightwatcher on Sun Mar 11, 2018 7:58 am, edited 1 time in total.
Fourdee
Post by Fourdee »
midnightwatcher wrote:26.1 GB /root
26.1GB of data is inside /root directory.
You'll need to run following command to find out more:
G_TREESIZE /root
Then continue to follow the highest number with command again, eg:
G_TREESIZE /root/thisfolder
midnightwatcher
Thanks Fourdee, I think I found the problem. It looks like DietPi-Sync tried to backup one of my external drives locally, will report back later this evening ...
Update: Confirmed. I've deleted the offending directory and updated to 6.4 without issue. I've also now properly mounted my drives using their UUID in fstab and did a bit of cleaning up to ensure I don't have a repeat of the same issue.
Thanks for your help!
