Issues with apt-get, NTPD timesync with DietPi
k-plan
Re: Issues with apt-get, NTPD timesync with DietPi
Post by k-plan »
Hi ptrinh1979,
ptrinh1979 wrote:- what text editor is available in DietPi by default?
nano
antalattila
Post by antalattila »
Same here.
I discovered minimum two issues here. the config file entry is not correct and at boot time is not working.
To fix the config file is quite easy. Pease do:
nano /etc/systemd/timesyncd.conf
correct the entry server=.. to FallbackNTP=.. and done.
At boot time you will have the issue but it will fix the time at the next hour or if you run the following command manually:
systemctl restart systemd-timesyncd
you reacted on a 2 years old entry. Not sure if there is any relation to your issue.
usually your config file should looks like this:
root@DietPi3:~# cat /etc/systemd/timesyncd.conf
[Time]
Servers=0.pool.ntp.org 1.pool.ntp.org 2.pool.ntp.org 3.pool.ntp.org
root@DietPi3:~#
next to this, the time server can be changed using dietpi-config tool.
and yes, during boot systemd-timesyncd is executed already and will update your system time. To check you can do the following after reboot
journalctl -u systemd-timesyncd.service
systemctl status systemd-timesyncd.service
if system time is not updated during boot, something seems to be wrong on your device.
