It didn't work for me here on the Z83 - tried using the first method of manually editing the three files to sda, sdb etc - no luck.
Tried the new method with install menu but same story. I ctrl-c'd out of Clonezilla and did # blkid - the eMMc and the install USB drive showed but the target USB drive didn't. # lsusb showed all drives. Why would that be?
Swapped the install and target drives round the three USB ports, but the install drive always grabbed sda.
Anyway decided to have a third attempt at installing to eMMC so after a backup - all went well. Have pretty much got the system running as it was before, Emby busy rescanning my media library.
Thanks Fourdee and your associates for all your work on this. I'll tackle the XU4 next - easier prospect just shuffling SD cards.
John
Native PC for UEFI ver6.0 Error [SOLVED]
Re: Native PC for UEFI ver6.0 Error
Yes, this particular device uses USB power so once the PC is powered up it receives power and is on...Fourdee wrote: usb-dac detection requires the DAC to be attached (powered on), else DietPi will not find the device index. Was the unit attached, powered on?
Also I noticed that when I try to install LMS it looks for the ARM version. Don't know if that was the problem but it would not install via the Dietpi GUI. I had to uninstall LMS via the GUI and install it manually.
First install
sudo apt-get install libio-socket-ssl-perl
Then do a wget from the Nightly build page for my device [x86_64], from there a sudo dpkg -i .... and everything was fine.
Re: Native PC for UEFI ver6.0 Error [SOLVED]
Hi Johnjohnvick wrote:It didn't work for me here on the Z83 - tried using the first method of manually editing the three files to sda, sdb etc - no luck.
John
Just for reference, I didn't change anything in the files ie sda etc.
I just replaces the two files with those in the zip. I did have some problems with my bios recognizing the USB with the Dietpi/Conzilla at first, after a couple of attempts it recognized it.
Confirmed, we'll investigate.Edward wrote:Also I noticed that when I try to install LMS it looks for the ARM version. Don't know if that was the problem but it would not install via the Dietpi GUI. I had to uninstall LMS via the GUI and install it manually.
