Odroid HC-2
secpri
Re: Odroid HC-2
Post by secpri »
I'll try it next week, then can give you a review.
secpri
Re: Odroid HC-2
Post by secpri »
The Cooling of HC-2 doesn't work as it should!, see Benchmark results.
For Tests i glue 2x 100x100mm Fans direct on the Heatsink and powered them external.
Room Temp: 21 °C
HDD: in sleeping mode (so less heat from it)
Test 1 - Full Power:
CPU Governor: performance
CPU: 4x 1400 Mhz + 4x 20000 Mhz
Cooling aktiv: YES
Result:
Test 2:
CPU: 4x 1400 Mhz + 4x 1800 Mhz
Cooling aktiv: YES
Result:
Test 3:
CPU: 4x 1400 Mhz + 4x 1400 Mhz
Cooling aktiv: YES
Result:
Test 4:
Cooling aktiv: NO
Result:
