Kodi 15.2 for DietPi Wheezy Topic is solved
Fourdee
Re: Kodi 15.2 for DietPi Wheezy
Post by Fourdee »
dogdayfear wrote:I think nothing has changed. I did a fresh install of DietPi Jessie and still Kodi 14.2 via dietpi-software.
Any news?
Hi Dogdayfear,
I've had to put this on the back burner (low priority) as I simply dont have the time available at the moment. Have you tested/tried your Kodi 15.2 with DietPi Jessie v109, is it stable?
dogdayfear
Post by dogdayfear »
Fourdee wrote: Have you tested/tried your Kodi 15.2 with DietPi Jessie v109, is it stable?
Nop. I have tried Jessie for 4 or 5 times over the time. I always find the same problem that I cant solve and is this: I cant shutdown my system with
halt
command. Gives an error about shutting down ssh sessions. And I havent been able to correct it. Belive me I have searched for a solution, googling for hours to solve it but no luck. I cant halt my system. Thats because I always back to Wheezy.
And if I had Jessie I will have to compile Kodi from source for Jessie. Different dependencies for both. I think I would do it. But first I have to feel comfortable with Jessie. And the halt system problem follows me from the beggining of the times. :)
dogdayfear
Solved the 'halt' problem. Now use poweroff instead.
So I have to compile from source to Jessie. Mmmm .... getting off the mud again. :)
Fourdee
Post by Fourdee »
dogdayfear wrote:Solved the 'halt' problem. Now use poweroff instead.
I use poweroff also, and reboot commands.
You dont need to recompile for Jessie, its only a suggestion as Wheezy is being phased out (see RPI Wheezy Image section. But if you do, let us know how 15.2 runs on Jessie.
thof
Post by thof »
I'm running 15.2 very stable on a RPi2, the only issue that sometimes occurs is that the audio renderer crashes after playing for a long time. When this happens video playback is stuck and you have to reboot.
dogdayfear
thof wrote:I'm running 15.2 very stable on a RPi2, the only issue that sometimes occurs is that the audio renderer crashes after playing for a long time. When this happens video playback is stuck and you have to reboot.
Are you referring to 15.2 version I compiled or other version?
Thanks.
thof
Post by thof »
Not sure, I installed Kodi through the Dietpi menu, so don't think it's yours.
I'm running Jessie, yours is for Wheezy right?
dogdayfear
thof wrote:Not sure, I installed Kodi through the Dietpi menu, so don't think it's yours.
Yes, mine is Wheezy.
I dont understand how you are running 15.2 if you installed through Dietpi menu. I think Fourdee still is using and old version of Kodi with the Dietpi install script.
Thanks anyway.
Fourdee
Post by Fourdee »
Thanks anyway.
Yep, for wheezy we use the following repo:
deb http://archive.mene.za.net/raspbian wheezy contrib as per Micheal's guide http://michael.gorven.za.net/raspberrypi/xbmc
Which was 14.x last time I checked (been a while). But the repo may have updated their version, would need to verify.
On RPi Jessie, its a straight forward apt-get install Kodi | from raspbian repo.
Odroids are apt-get install kodi-odroid | packages created by Meveric
